OK, So you got your old rusty frame replaced....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frito, Jan 30, 2016.
  1. Jan 30, 2016 at 8:21 AM
    Frito
    Frito [OP] Well-Known Member
    How did you prepare ?
    What advise have you for me ?
    What did you pre-plan to replace ?
    What would you do different ?
  2. Jan 30, 2016 at 8:44 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Many are replacing struts/coil assemblies since the rear leafs, and lower control arms are being replaced by the dealer. That way you end up with all new suspension as well as a frame. Better off buying any parts you need yourself, and having the dealer replace them. Most dealers will not charge for labor on the parts that needed to be removed anyway. Ask the tech to give you a heads up on anything that he sees during check in that may be questionable. My dealer's tech did a walk through with me before drop off. It's a good time for 5100's, if you were considering them.
  3. Jan 30, 2016 at 8:49 AM
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    I agree with above. I have an icon stage 3 being installed and new LR UCAs. I am also having them replace the intermediate steering shaft as my u joint is bad. I told them to call me with anything else they see that looks questionable. Getting frame replaced in a month from now.
  4. Feb 2, 2016 at 7:41 AM
    Frito
    Thanks !
