OK, the 3.5 should be a good engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jan 29, 2015.
  1. May 27, 2015 at 3:09 PM
    #541
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Youre going to call people "stupid", and such, yet you didn't even comprehend the post. He said,
    He's not talking about the "owners" of the trucks, but Toyota. And, he's right. Both engines listed have less volumetric efficiency than the 3.5 will have. VE is one of the largest contributers of how well an engine will perform in fuel efficiency, along with gearing, drive train efficiency, frontal area, rolling resistance, weight, etc.
    To add, Im pretty sick of you name calling. If you cant contribute to this thread, in a meaningful way, without the name calling, and insults, then I will block your ability to respond in here completely.
    T-Rex266 likes this.
  2. May 27, 2015 at 3:20 PM
    #542
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    You do realize Toyota is already the world's most fuel efficient full line manufacturer right?? Can't of hard beat everyone when you're already #1 :)
  3. May 27, 2015 at 4:02 PM
    #543
    tunerpike
    tunerpike Well-Known Member
    I'm a controls engineer and cover all of the northern half of Alabama.. A lot of my customers are automotive based.. Honda, Mercedes, Toyota and all teir manufactures..
    Toyotas engine plant TMMA is in Huntsville, AL.. I have been helping them with a lot of poka-yoke applications with the new 3.5 engine... They ran the first batch of 100 the first of Feb and another batch in May.. They will then tear them apart and investigate everything about them. I have helped them with a number of different sensors and vision systems to measure trueness of the heads, water jackets, rods, cranks.. etc..
    I asked them why they changed to the 3.5 and they said that Toyota is moving to a common engine platform.. In other words one engine can work in several different vehicles.. Full production starts in August.
  4. May 27, 2015 at 4:03 PM
    #544
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    First: I called his statement stupid and not him.
    Second: Feel free to block me, if thats what you think.
    Maybe we should burn science books also.
    His statement just like many here is based on some twisted logic, and wishful thinking.
    Now some info..
    V12 Audi A8 that has Curb weight of 4800LB has MPG...
    14/22
    Thats a 6.3 Liter v12 engine.. in the car that weights more than Double Cab long bed...
    As I said displacement and number of cylinder has very little to do with end MPG.
    But folks can believe in whatever Unicorns they want.
  5. May 27, 2015 at 4:08 PM
    #545
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    mang those V8 Collies...were a hoot to drive...too bad the platform was such a POS.
    V8+Tacoma=:drool::drool::drool:
    I would have to agree with BlueT on that one, the DCLB Taco needs a V8. Of course...think you're better off buying an extra cab short bed fullsize instead of the the DCLB Taco. Wheel base is darn close...I know a Silverado has 143" WB, (Taco DCLB is 140" IIRC) track is a little more..and just a bit more rear seat leg room.
  6. May 27, 2015 at 4:26 PM
    #546
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    You're comparing apples and oranges.
    The Tacoma has the aerodynamic drag of a brick. The Audi is dramatically better there. Makes a huge difference.
    Mike Sweers said they put a lot of effort into aerodynamics for 2016 because it helped fuel economy. Same reason GM uses the giant air dams on their front ends.
  7. May 27, 2015 at 4:39 PM
    #547
    Yota64
    Yota64 Professional Threadjacker
    You can care about fuel economy without it being the only driving force of your purchase. The v6 4x4 long bed is a common option because of how functional it is, that doesn't mean owners don't care about the mpg. When a midsized truck is coming close to getting beat out in the efficiency department by full size trucks, something is wrong and that's why a lot of people turn to the full size market. They want the functionality of a v6 4x4 long bed without the efficiency of a tank, especially when it can be had across the road at the Ford dealership.
    Have you ever heard of the Dodge Dakota? If so, there's a reason. If not, there's a reason.
    He never claimed fuel economy was the only choice the buy a vehicle. He claimed fuel economy was what the Tacoma needed.
    This isn't the first time you've responded to a sound argument in a way that seems almost like you have a personal problem with the other party.
    Not in the truck department by a long shot. In 2005, which is where every Tacoma on the road today is from, it was #1 in nearly every category. After that, other manufacturers stepped up their game and Toyota didn't produce anything new because it didn't have to, due to Tacoma sales numbers. I really hope they come out again and crush the competition.
    On this forum the biggest comparison I see is to the F-150. Not because they're in the same class, but because they're two popular buying choices, and the Ford F-150 has pretty much the same mpg as well as more creature comforts and towing capacity.
    So Toyota really needs to get this truck up there with the numbers.
    Jayhawk815 and Delford like this.
  8. May 27, 2015 at 4:39 PM
    #548
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Weren't you just talking about aerodynamics determining MPG...
  9. May 27, 2015 at 5:05 PM
    #549
    Jaque8
    2017 Inferno TRD OR
    OH YEAH!? Well let me tell you something about that! You are so wrong buddy, SO SO WRONG! Let me explain why... you see... uh... well...
    fuck it you're right.
    Yota64[QUOTED] likes this.
  10. May 27, 2015 at 6:11 PM
    #550
    7GR
    7GR Well-Known Member
    GSJ15W
    Logic has no place in his discussion :laugh:
    I'm starting to think the dude in his avatar is actually how he looks like in real life, and that would explain A LOT :D
  11. May 27, 2015 at 6:42 PM
    #551
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Getting back to topic, this ^.
    For example a Ford 5.4 L Triton put out 260 hp (194 kW) and 350 lb·ft (475 N·m) in 2004. I had friends with this truck and they got somewhere around 15 mpg combined on a good day. Now Ford has the 5.0 L Coyote in there truck putting out 385 hp (287 kW) and 387 lb·ft (525 N·m). My wife gets close to 20 mpg with our 2015 F150 XTR 4x4 Crew. That's a massive jump in that time span while increasing power, decreasing displacement, and increased mileage. Both the engines I mentioned are in the same engine family, much like the 1 GR and 7 GR.
    I hope Toyota's 3.5 L 7GR will keep up with this change and impress us all.
    Delford likes this.
  12. May 27, 2015 at 9:38 PM
    #552
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I don't see how it wouldn't. Every manufacture has a three and a half liter engine that out performs the 1GR. Granted, Toyota has never been one to enter into a horse power war, the new engine will undoubtedly be an acceptable replacement. I would bet it will be close to 300 hp, and 270 tq. Hell........The new Honda Rigeline engine is going to be around 285 hp out of its 3.5 engine. The Pentistar 3.6 is 300+, Ford and Chevy are following suit. Personally..........im wondering what Nissan has up their sleeve.
  13. May 27, 2015 at 9:43 PM
    #553
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    I wonder ir Nissan may exit the mid sized market or let it wither considering the Titan and the Frontier used to share so many parts. I know that Nissan toyed around with the 4BT engine in the Nissan but that engine is loud and not really suited to the average buyer in the midsized market. With the lack of Frontier announcements it does beg the question if Nissan has decided to concentrate on the Titan and trying to grow it rather then the Frontier.
  14. May 27, 2015 at 9:45 PM
    #554
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    RAM is going to be making the new Titan. Kinda like what they did for Mitsubishi when they wanted a truck. As for the Fronty, they could be doing what Toyota did, and let it ride for a while. Not sure when the last redesign was for it.
  15. May 27, 2015 at 9:50 PM
    #555
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Ram is making it? I didn't know that. I knew they negotiated for a while about rebadging the Ram as the next Titan but I didn't know that something came of it.
    Dodge has a long history of rebadging and running with equipment for and from other manufacturers. Most of those situations turned out poor vehicles.
  16. May 27, 2015 at 9:56 PM
    #556
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I did some digging, and it seems the co op has stalled over the last year. Originally () RAm was going to provide the drive trains, and chasis, but Im not sure when, or if this is going to take place now.
  17. May 27, 2015 at 10:04 PM
    #557
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
  18. May 27, 2015 at 10:15 PM
    #558
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    That's what I thought.
    It's a good thing in the end. A rebranded Ram isn't worth what Nissan would try to sell it for. I'm still curious to see the Titan XD when it comes out. A lot of guys around here in the patch bought pro 4x Titans when they first came out then traded them off almost immediately after they started having mechanical issues. If this Titan can hold up and has a diesel engine I can see a couple of rig pigs grabbing one.
  19. May 27, 2015 at 10:27 PM
    #559
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Jesus, as your avatar suggests...
    No, that would not be the engine of choice. Numbers don't lie period! There are more stringent numbers for fuel economy standards coming down the line! Sorry haas but Toyota didn't consult you when they built the Tacoma nor did they consult you when they designed the engine because in your infinite wisdom they'd be offering a 15L V8 with 3,000HP so you could haul your 15 sheets of 3/4" plywood and not notice it. Off the pedestal on which you've placed yourself. There is a small demographic of enthusiasts who look to improve their trucks. I work on a base with untold number of Tacoma's. Of the 43 that are on base I can count 3 of them who have owners who care about the engine the others, I've complimented them on their trucks and have heard this... "Meh, it's a ok truck. I bought it because I needed a truck and there wasn't much out there. Needed a double cab for the family". For what it's worth, at least 1/3rd of them are double cab short beds with the 2.7. Not one of them has said anything about the engine.
  20. May 27, 2015 at 10:38 PM
    #560
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Your thought process is illogical as is your statement to burn science books.
    Obviously you are a physics major... Its apples to oranges. You're comparing a supercar that has been designed to have a significantly lower coefficient of drag, lower rolling resistance, finely tuned transmission and drive train as well as a super car that has been tested to SAE standards. For fucks sake I can get 24mpg out of my 4Runner with 3" of lift and 285's rolling down a flat stretch of freeway at 65mph. Hell, I consistently see 16mpg in the city.
