OK, the 3.5 should be a good engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jan 29, 2015.
  1. Jun 2, 2015 at 10:53 AM
    #581
    buckwild
    buckwild Active Member
    Bill
    Frankfort, KY
    '12 d/c sport, tow pkg
    X-tang hard top bed cover, Aries black tube steps, Aries hood & window gaurds
    The new engine will have two types of fuel injection. For regular driving it will use the standard fuel injectors, for an extra boost in power it will have direct inject. Toyota like others will have to find a way to get more MPG's in the coming years. The new engine we have tested for the Lexus, Avalon, Camry, will have 305 hp.
  2. Jun 2, 2015 at 10:57 AM
    #582
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Thanks! Any idea on torque?
  3. Jun 2, 2015 at 11:05 AM
    #583
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    In theory the Tacoma can use the same motor as the Toyota cars and even through it produces the same amount of power to the crank. With a differential gear ratio (such as a 4.10 stock for the v6) it should still feel like it has the low end power off the line. The 1st gen 3.4 v6 Tacoma came stock with a 4.10 gear ratio and it felt pretty good at low rpms even though the power numbers were relatively low to the crank. The new motor will most likely have a 6 speed tranny that is very different from any car application so it won't feel anything like the engines in the camry and avalon. It's been a long time since Toyota has built a bad motor especially for it's trucks/ SUV's so I'm not worried about it at all here.
  4. Jun 2, 2015 at 11:13 AM
    #584
    Yota64
    Yota64 Professional Threadjacker
    Why wouldn't they use direct injection all the time? Isn't that what everyone's raving about? Also, are you saying the 2016 will have 305 hp? That's a lot more than most are guessing.
  5. Jun 2, 2015 at 11:33 AM
    #585
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Direct injection isn't good for low end torque. Trucks like low end torque.
  6. Jun 2, 2015 at 12:35 PM
    #586
    buckwild
    Bill
    Frankfort, KY
    I don't know how the setup will be for the taco. I've heard that the lobes on the cams may be different and the timing set different to adjust for more torque thus losing a little bit of horsepower. As far as direct injection, there is more machining required for the engine and more complicated programs for ECU, thus more cost. I can tell you the test we put these engines through are far beyond anything that will be in any taco and they definitely prove themselves.
  7. Jun 2, 2015 at 12:51 PM
    #587
    ThisSideofSane
    ThisSideofSane Contingency Solar
    Marcus Remington
    Charleston, SC
    08 DCSB TRD OR V6 4x4
    I wonder how long it'll be before BlueT shows up to tell you you're wrong.
    Lord Helmet, dmanny, Yota64 and 3 others like this.
  8. Jun 2, 2015 at 12:53 PM
    #588
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Don't forget that he'll use all his angry words, question your intelligence, ancestry, and tell you that anything other than diesel is a sin.
  9. Jun 2, 2015 at 1:26 PM
    #589
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Why would I do That? he is 100% correct :notsure:
  10. Jun 2, 2015 at 1:29 PM
    #590
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    No minivan comment?
    Lord Helmet and ThisSideofSane like this.
  11. Jun 2, 2015 at 1:43 PM
    #591
    Yota64
    I was under the impression that direct injection was just an improvement in general
    That makes sense. As far as direct injection costing more, isn't this what other manufacturers started doing 10 years ago? The Tacoma is pretty pricey already too.
    Are you saying with that last bit that this engine you're talking about will or will not be in the Tacoma?
  12. Jun 2, 2015 at 1:45 PM
    #592
    Yota64
    Okay MikeDeason
  13. Jun 2, 2015 at 2:23 PM
    #593
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Sounds like we're getting a less advanced version of it.
  14. Jun 2, 2015 at 3:04 PM
    #594
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    the new tacoma trd off road will have 4.30 gears and a 8.75 inch rear end. also the tail gate has been reenforced and is just thicker over all. the elocker is new and ill be more internal than the old one
    dmanny likes this.
  15. Jun 2, 2015 at 3:50 PM
    #595
    dmanny
    dmanny Member
    Santa Cruz
    94' 4runner
    The engine also has port injection. I imagine that it can have the best of both worlds?
    buckwild likes this.
  16. Jun 2, 2015 at 3:53 PM
    #596
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    If properly implemented with the right cams then yes.
  17. Jun 2, 2015 at 4:11 PM
    #597
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Direct injection engines are also prone to carbon buildup. Haven't port injection as well should help with the carbon issues.
  18. Jun 2, 2015 at 5:13 PM
    #598
    dmanny
    dmanny Member
    Santa Cruz
    94' 4runner
    Will the 4.3 gear ratio make it unnecessary to re-gear if you want to run 33's?
  19. Jun 2, 2015 at 5:35 PM
    #599
    wrmathis
    Bonaire, GA
    parts and stuff
    Hell if I know. All depends on the gearing in the tranny
    Lord Helmet likes this.
  20. Jun 2, 2015 at 7:02 PM
    #600
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Likely no.
    The 4.3 gear ratio is probably to make up for a lower torque output from this new motor over the 4.0 L or a different set of transmission ratios. Either way your truck is still going to feel like it's working harder on 33's just like the current Tacoma's.
    My Tacoma is on 33's and I don't feel like it hurt the truck that much....
    I think you need gears for 35's on the 2nd generation Tacoma, but at 33's you can get by fine.
