OK, the 3.5 should be a good engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shr133, Jan 29, 2015.
  1. Jun 3, 2015 at 9:04 PM
    #621
    Master_Yota
    Master_Yota Well-Known Member
    Northeastern U.S.
    2017 Toyota Tacoma OR
    My question is at what point does pushing the envelope create an engine that has less durability and reliability due to running harder at higher RPMs. Just a question that I don,t have an answer for.
  2. Jun 3, 2015 at 9:48 PM
    #622
    buckwild
    buckwild Active Member
    Bill
    Frankfort, KY
    '12 d/c sport, tow pkg
    X-tang hard top bed cover, Aries black tube steps, Aries hood & window gaurds
    I'm sitting here looking at a 3.5 torn down after a durability test. It was ran @ 6400 rpm / full load. It WILL handle the load. BTW, we never change the oil in most tests! Makes me a firm believer in synthetic.
    nv529 likes this.
  3. Jun 4, 2015 at 5:02 AM
    #623
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Nissan pretty much led the charge on this idea with their VQ35 engine back in the early 2000's. It was in EVERYTHING from the 350z, Altima, Maxima, Frontier, Xterra, Rouge, Murano, Quest Minivan, and the Infiniti models too....literally every car they make except the small economy boxes that only offered 4 cylinders. You could also say that GM did a similar thing with their smallblock V8 but the applications just weren't as widespread.
    God I wish you should share more info with us. I'd kill to see the things you're seeing! :D
    What kind of test parameters were there? Simulated load, duration, cooling, etc...
  4. Jun 4, 2015 at 5:31 AM
    #624
    ThisSideofSane
    ThisSideofSane Contingency Solar
    Marcus Remington
    Charleston, SC
    08 DCSB TRD OR V6 4x4
    Mitsubishi was doing that with the 3000GT line back in the early-mid 90s. All the trim/performance levels had the same block, but with an NA SOHC, NA DOHC, and the twin turbo DOHC heads. I have no clue if they did anything like that with anything else they offered though.
  5. Jun 4, 2015 at 6:42 AM
    #625
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    With DI, the compression ratio can be increased, without issue, giving more torque. Smaller size, generally, gives a lower piston velocity, wich can increase life. Many of these new engines have much better cooling, and lubrication properties, so life span is a non issue.
  6. Jun 4, 2015 at 7:59 AM
    #626
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think that ship has sailed. its not Pushing envelope that creates problems, its going cheap (like putting car engine in the truck) that creates problems.
    Also swapping truck parts with less expensive cheaper parts.
    ExampleS?
    #1. Wheel bearings on 2gen. Made in China with plastic roller cages.
    #2. Not many people realize that some of the internals of 1GR on Tacoma were swapped to cheaper replacements. If you open 05-08 engine. Those manufactured in Japan (yes there are some) will have part numbers that can be traced to Prado/Land Cruiser parts. if you try to get those parts for Tacoma they are now different parts (more cheaply made)
    This is why a lot of guys with 05-08 will hit A lot of miles on their trucks, in the meantime a lot of 2014 guys are complaining about oil pump failures and weird engine noises.
    Now going back to your question, which can be best answered with simple math.
    1 GR 2 Gen has gear ratio of 3.73 at the wheels. If we say trucks run with the same size tires.
    2.5 Gen with gear ratio of 4.30 will wear 13% more of its power train components than 2gen.
    Simeple think, that rubber seal that prevents transmission oil from leaking will have to survive 13% more rotations. Now if that seal was made for trucks that seal would have built in extra material, but since as many people stated Toyota is pretty much pullign this out of their car fleet, You can bet your A$$ that seal is going to be something cheap. Btu wait there is more.
    On new truck 1gear is 20% lower than what 2 gen truck does
    That means overall you are looking at 30% wear increase on the engine every time you are on 1gear.
    Since new transmission combining with new gear is lower than 2gen on every gear 1-4 and only 5th and 6th are higher, unless you buying 2.5 gen to drive on anything but the highway you will get massively increased wear. Considering this is car engine so Truck duty in dust, snow, water etc will only make things worse. You could be looking at the much shorter life span.
    Will that truck survive warranty? In majority cases yes.
    Will that be the same long lasting, unbreakable Toyota truck..... Definitely no.
    Its End of the Era, Toyota is taking the same path as GM and we all know how great this is working out for GM.
  7. Jun 4, 2015 at 8:03 AM
    #627
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What youre not taking into consideration, is the less work the engine is required to put out with the better gears. Yeah, there may be a few % more rotations, but it will be a certain percent less work load on the drive train.
  8. Jun 4, 2015 at 8:21 AM
    #628
    BlueT
    NorthEast
    They will be still pulling 4800LB truck.
    Simple.
    if you had two trucks, exactly the same. And drove one on 4Hi and other on 4L (2:1 ratio) only.
    Would you change oil on both trucks at 5000 miles or one at 5000 and other at 2500 miles?
  9. Jun 4, 2015 at 8:37 AM
    #629
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not really an "Apples to Apples" compare you have there
  10. Jun 4, 2015 at 8:56 AM
    #630
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    It's BlueT. He likes to compare apples and rhinoceroses.
    nv529 and yotarob2005 like this.
  11. Jun 4, 2015 at 9:03 AM
    #631
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    He could have very well left 4 wheel drive out of the equation, and suggested one vehicle in 5th gear, vs one in first.....
  12. Jun 4, 2015 at 9:04 AM
    #632
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    Your correct but still exaggerating slightly
    Actually he likes to compare mid sized trucks to 1 ton trucks
    And girl motors to boy motors? What ever the hell that means.
    nv529 likes this.
  13. Jun 4, 2015 at 9:13 AM
    #633
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Yes, him and his buddy think that engines have genitals. It's amusing.
    yotarob2005[QUOTED] likes this.
  14. Jun 4, 2015 at 9:20 AM
    #634
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    The 2016 has a van motor. We've got people on here complaining about the GM twins 3.6L and that they drove it and it "sucked". Do you really expect the "new" 3.5L Tacoma with the same 6-speed auto and same design to be any better? Much like the 2015 Colorado the 2016 Tacoma will be much heavier than the comparable 2nd gen. Any "gains" in HP will be nullified because of the weight. It'll probably be quicker unloaded, but loaded is a different story.
    The V8 Colorado is quicker all around than the 2nd gen V6. When both are loaded to GVW the Tacoma accelerates quicker. A testament to the fact that Toyota designed the 2nd gen for actual truck duty. Whereas the 2016 is designed for soccer moms to do Costco runs.
  15. Jun 4, 2015 at 9:28 AM
    #635
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Are we talking the V8 Colorado from back 5 years ago? Because GM doesn't make a V8 Colorado right now.
    I know you're exaggerating but the Ford Coyote V8 and Ecoboost are found in many Ford cars and "vans". Does that mean the most reliable truck in our work fleet is powered by a van motor? If so I'm all for van motors. The "van" engine in my wifes truck has no problem moving 6000 lbs of camping gear behind us without ever breaking 4000 RPM. The Colorado can't do that with even 3500 lbs behind it.
    The problem with the Colorado is that the motor is screaming anytime you ask it for power because it's best power production is right against the redline. I'm hoping Toyota will have a flatter torque curve due to better tuning for the application. Until the 2016 is out we won't know how "van-ish" the Tacoma will be compared to the Colorado.
    yotarob2005 likes this.
  16. Jun 4, 2015 at 9:29 AM
    #636
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Completely false. According to Toyota the frame will be made with higher strength steel which will increase rigidity and be lighter. Comparing Toyota and GM engines is comparing apples and oranges. Just because the 3.6 in the Colorado has specific traits doesn't mean that the Tacoma will be the same in any way.
  17. Jun 4, 2015 at 9:30 AM
    #637
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    blah blah blah truck stuff... MERICA!!!
  18. Jun 4, 2015 at 9:33 AM
    #638
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    A coworker just got rid of her 2011 Cadillac SRX because that GM 3.6 decided to stop playing nice with others. She bought a Ford Edge, and is starting to realize that mistake as well after driving her son in-law's Venza.
    From what I've seen, that 3.6 is either great or it's crap. I don't feel like playing engine roulette.
  19. Jun 4, 2015 at 9:33 AM
    #639
    CaptAmerica
    Cap
    Yes? I like truck stuff...
  20. Jun 4, 2015 at 9:38 AM
    #640
    ItalynStylion
    Steven
    DFW, Tx.
    Whoever started the fallacy that a "van" motor is any worse than a "truck" motor needs to be repeatedly kicked in the nuts; then shot....twice
    The 1GR-FE in our trucks right now is just as much of a "van" motor as the new one will be. It's virtually the same damn block as many other GR engines with a longer stroke and different heads. The damn connecting rods are longer; this doesn't make it an invincible truck engine. Wake the hell up people.
    If anything, it would make it LESS reliable due to higher piston velocity, like Chris 4x4 was talking about. So much so, Toyota had to REDUCE the reline to ensure it didn't tear itself apart at high RPM.
    buckwild and Sterdog like this.
