Ok to use impact on LCA bolts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco dv, Feb 21, 2025.
  1. Feb 21, 2025 at 11:22 AM
    Taco dv
    Taco dv [OP] Well-Known Member
    2020 Tacoma TRD off-road
    I’m going to be installing new front shocks. Is it ok to use an impact gun to loosen the LCA bolts, and the other high torque bolts? Just want to be sure with the LCA having adjustment bolts.
    Will be torqued to spec after.
  2. Feb 21, 2025 at 12:04 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    Yes, if your impact gun can loosen it. I normally crack the nut loose with my hand tools (breaker bar), then using an impact to remove the nut.
    Cheers
    Taco dv[OP] and gotoman1969 like this.
  3. Feb 21, 2025 at 1:02 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    If your impact can't break a lca bolt it's time to upgrade.
    But to op yes I remove as many bolts as I can with an impact on installation is a different story. I'll typically run everything on with an electric ratchet then snug followed by a proper torque.
  4. Feb 21, 2025 at 1:17 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    When installing best to start and first few turns by hand.
  5. Feb 21, 2025 at 1:27 PM
    Shellshock
    Iowa
    You can but you can do front shocks without touching the LCA bolts. You just separate the spindle from the UCA and you can push the LCA down enough to get the shock out. Lots of people have done it this way instead of undoing the bolts on the LCAs
    Taco dv[QUOTED][OP] likes this.
