OK, what did I do wrong?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 45er, Aug 15, 2016.
  1. Aug 16, 2016 at 6:50 PM
    #61
    Q1000
    Q1000 Well-Known Member
    Ontario, Canada
    2016 Alpine White TRD Sport (CDN Specs)
    Hey fellow S2k/Taco owner
  2. Aug 16, 2016 at 6:57 PM
    #62
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    You forgot the fill the compressor up with air BEFORE leaving the house:frusty:
    The outlet could not even power my small coffee machine one night when camping, pathetic.
  3. Aug 16, 2016 at 11:41 PM
    #63
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    A pancake compressor can easily need 1500 watts... So can one of your most expensive to operate appliances; a coffee maker...whaaaaaaa? Thanks for another complaining bitch thread though. The forum just doesn't have enough of these.
  4. Aug 16, 2016 at 11:52 PM
    #64
    John taco
    JT - Johnny
    King of Prussia PA
    yikes lighten up there fella, someones not happy about there cool bed outlet power supply after purchasing a new 2016 truck. OP was simply stating how weak the power outlet was.
  5. Aug 17, 2016 at 12:13 AM
    #65
    Lord Humongous
    AZ
    You can use the outlet to charge an IPad while you search for a Ridgeline dealer. I heard they have a 100 amp bed plug and they are throwing out bonuses for tacoma trade ins!
  6. Aug 17, 2016 at 12:40 AM
    #66
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    The problem with our inverters (2nd gens included) is they have a square wave on the output. Most motors don't react well to being fed a square wave. If you want an inverter to really run anything (within the chosen inverters power range) you would need a pure sine wave inverter, and they are more expensive than the run of the mill inverters we have in our trucks.
    Just remember to do your math when installing or changing out to a larger inverter. Some will require significantly larger wiring than stock. Stay safe, electrical issues are the second leading cause of car fires:bananadead:
  7. Aug 17, 2016 at 1:24 AM
    #67
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    plugged my circular saw in mine and it ran fine..
  8. Aug 17, 2016 at 11:12 AM
    #68
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Certainly runs my 13" macbook... Which needs a whopping 60 watts @ 120vac. :)
    You must own the wimpiest circular saw on the planet. Most require 7-8 amps once they have been started, more when they are loaded. You are not going to get that from a 3 1/3 amp inverter.
    robssol likes this.
  9. Aug 18, 2016 at 1:01 PM
    #69
    K9kodi
    K9kodi Well-Known Member
    1997 Tacoma x cab 4x4 2.7
    3" body 2.5" spacer
    I've heard some folks on Cummins motors forums complain about some stuff, but if the inverter in your pickup truck bed is not powerful enough to run what you want you should have don't me research prior to or you make it better. Coffe pots? Laptops? iPads? Really? It's a truck.
