OK, who did this? Speak up!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by guru, Jun 13, 2019.
  1. Jun 13, 2019 at 8:05 AM
    #41
    Trail Swag
    Trail Swag Well-Known Member
    Trail
    2016 DCSB TRDOR
    Rock chips 'n pinstripes
    I'm not sure I want to google "dilly piddler"...
  2. Jun 13, 2019 at 8:05 AM
    #42
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    ^ This.
    Props to the guy for realizing his mistake and backing up.
    I'm just stoked someone got it on video to give us a chuckle.
  3. Jun 13, 2019 at 8:06 AM
    #43
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    The driver of that truck is about to start another website..
    Neverbuyatacomaoffraod2.com
    :rofl::rofl::rofl:
  4. Jun 13, 2019 at 8:08 AM
    #44
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    It’ll be some kind of lemon law post
  5. Jun 13, 2019 at 8:10 AM
    #45
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    And for once when Toyota says it’s normal, it will be...
    Crodell6[QUOTED] likes this.
  6. Jun 13, 2019 at 8:22 AM
    #46
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    IDK, the height of the snorkel opening is at least 5 feet above the ground, so that is the depth that you can ford a creek...right?
    Lawfarin likes this.
  7. Jun 13, 2019 at 8:29 AM
    #47
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    NOPE!
    The snorkel isn't fully sealed so water can get in at the air box just like any other Tacoma!
    I hope that person installed the diff breathers on his truck or he needs to replace his fluids!
  8. Jun 13, 2019 at 8:43 AM
    #48
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    Not necessarily. The diff breathers are actually designed to avoid letting water in. It's just when they get clogged up with oil that they don't work and let water in. With a truck that new it won't likely be an issue. Wouldn't hurt to check though.
    DaveInDenver and Crodell6 like this.
  9. Jun 13, 2019 at 9:04 AM
    #49
    toku58
    Mall Crawler!
    REALLY? When did the design change? Is this something new?
  10. Jun 13, 2019 at 9:19 AM
    #50
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    I don’t know about that. The OE “breathers” are pretty flimsy and don’t seal entirely too well. Even if it did, the cooling of the diff and axle can draw water in through the axle seals.
    To my knowledge, it hasn’t.
  11. Jun 13, 2019 at 9:32 AM
    #51
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    YMMV
  12. Jun 13, 2019 at 9:32 AM
    #52
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    At least it didn’t start bubbling out white smoke....
    Good for them to back out.
    Running Board Man likes this.
  13. Jun 13, 2019 at 9:35 AM
    #53
    ToolPac
    Show Low, AZ
    Probably not. Do you really think you have to change your gear oil every time you dunk it in some water? I guess I better change mine every time I put my boat in the lake then. Which is exactly 3 times now with my new truck and probably about 150 times with my old one. Neither of them have modified diff breathers and neither of them have ever pulled water in.
  14. Jun 13, 2019 at 9:39 AM
    #54
    ryan760
    ryan760 Well-Known Member
    Should be illegal
  15. Jun 13, 2019 at 9:39 AM
    #55
    ToolPac
    Show Low, AZ
    Go pull yours out and try to suck water through it and get back to me. You'd have to have your diff running at about 300 degrees and drop it in about 20 feet of water before water could force it's way past the axle seals. Some of you guys are pretty gullible when it comes to "necessary" mods for wheeling and water crossing.:rofl:
  16. Jun 13, 2019 at 9:44 AM
    #56
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I think the snorkel looks sweet and does provide at least some small level of functionality as it grabs area from above the roof vs the wheel well. But if you're into STDs and drug addiction that's cool too
    Filterec likes this.
  17. Jun 13, 2019 at 9:48 AM
    #57
    Dryfly24
    George
    NM
    1) Not a sealed system so no functionality
    2) it’s called humor - look it up if you don’t know what it means so wrong again.
    Nice try anyway and Thanks for playing....
  18. Jun 13, 2019 at 9:51 AM
    #58
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  19. Jun 13, 2019 at 9:51 AM
    #59
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Fearthisbeard[QUOTED] likes this.
  20. Jun 13, 2019 at 9:52 AM
    #60
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Maybe for water crossing, but I'd bet it pulls cleaner air. Sick come back
    Dryfly24[QUOTED] likes this.
