Okay my truck will start up and idle great until it gets to operating temp. Once it's warmed up it m
Discussion in '1st Gen. Tacomas (1995-2004)' started by Brokenneck, Aug 13, 2024.
  1. Aug 13, 2024 at 5:49 PM
    Brokenneck
    Brokenneck [OP] Member
    Mark
    2001 tacoma 2.4L rear wheel drive xcab
    None
    What do I do to fix this problem I have to drive my wife 30 some miles to work every day. Once my truck warms up it starts to misfire and starts to cut out
  2. Aug 13, 2024 at 5:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check engine light on?
    If so, what codes?
  3. Aug 13, 2024 at 6:02 PM
    Brokenneck
    Mark
    None
    P0115 engine coolant temperature sensor 1 circuit
  4. Aug 13, 2024 at 6:03 PM
    Brokenneck
    Mark
    None
    I just replaced that sensor
  5. Aug 13, 2024 at 6:26 PM
    TnShooter
    Deogee
    STOCK
    If you have a scan tool. Look and see what the scan tool says the temp is under live data.
    Maybe it want the sensor, and it was the wires too the sensor.
    We can test that. But let’s see what live data says first.
    Cold engine. The temp should read close to outside air temp.
  6. Aug 13, 2024 at 6:31 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Ugh
    Brokenneck
    Check out my ETC thread
    Pretty much under yours
    my AM sensor choice failed after 6 months
  7. Aug 13, 2024 at 7:26 PM
    Brokenneck
    Mark
    None
    Now im getting a misfire on cylinder 1 along with engine coolant temperature sensor circuit 1
    PBwithJ likes this.
  8. Dec 22, 2024 at 10:59 AM
    PBwithJ
    PBwithJ Member
    joshua
    2002 Toyota Tacoma DLX extracab
    none
    similar issue, following ....
    i have no codes but after warms up will idle down to 500-600 (slight vibration/annoying)
    have replaced: maf, temp sens, both o2 sensors, adjusted throttle cables
    it will idle back up if i turn the wheel or turn on ac but then idles back down..
    2.4 185k, new to me truck I'm fine replacing what ive done so far cause it seemed to have little to no regular Maintenace.. beyond this point im just throwing $ at ?? since no codes
  9. Dec 22, 2024 at 7:56 PM
    Glamisman
    Glamisman Well-Known Member
    PBwithJ... pull the intake tube off and look in the throttle body and see if it is gunked up, if so, clean it.
