Okay, Okay, Okay
Discussion in 'Wheels & Tires' started by Grey Ghost, May 24, 2009.
  1. May 24, 2009 at 5:18 PM
    Grey Ghost
    Grey Ghost [OP] New Member
    Tennessee
    06 PreRunner SR5
    I have an '06 PreRunner, Double Cab, sitting on stock suspension with the stock 16" alloy wheels. SO...it's time to get new tires!! What better time to perform an upgrade?
    What I am wanting to do is put a bigger, wider, AT tire on black steelies. Given that, my question is twofold: What size rims should I get (will an upgrade to 17" be more trouble than it's worth)? And what size tires can I fit?
    I have done a fair amount of research on this site and others, and can't find a straight answer. In regards to the biggest tires that can be used, I've seen 265/75/16, 32" (what width?), 33", the same size have right now, and on and on and on. I really don't want to go to a 17" wheel, but with all of my internet searching, I haven't been able to find a good looking set of 16" wheels.
    OH...I suppose I should fill you all in on my level of off-road activity. I don't do much running in the mud, due to my lack of a 4WD, and lack of a lift (on top of the street rubber on the wheels!), but I do a little trail riding, mostly simple stuff. Nothing real hard core. Truth be told, I just like the beefier look. I had a '00 single cab 4WD, and ran 31" x 10.50's on it, and LOVED it. Really wanting to get that same kind of stance on my '06.
    Thanks ahead of time for the help, and I look forward to hearing from y'all.
  2. May 24, 2009 at 6:36 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    get whatever size rim in an 8" width and either a 265/75/16 or 265/70/17 since you are on stock suspension. thats the largest size tire you can do w/o hitting stuff
  3. May 24, 2009 at 6:46 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    If you do a few trails, stick with the 16" rims. The more tire sidewall between obstacles and rim the more protection
  4. May 25, 2009 at 10:05 AM
    Grey Ghost
    Tennessee
    06 PreRunner SR5
    And so it shall be. Right now it's a showdown between ProComp Xtreme Alloys Series 8069, and XD Series XD122.
    I'll wrap them in 265/75/16 rubber. I'll post pics when I get it put together. Thanks for the help, guys!!
  5. May 25, 2009 at 2:52 PM
    The_Hodge
    SC
    i almost had the xd122's in matte black, but were in an indefinate backorder
