Okay to drive in 2wd with dry front diff?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taco330, Jun 14, 2022.
  1. Jun 14, 2022 at 2:26 PM
    taco330
    taco330 [OP] Member
    I was trying to save some time this week, so took my truck by the me to change diff and T/C fluids. Well - they forgot to tighten the fill bolt on the front diff, and a bunch leaked out.
    I'm not 100% sure what spins when in 2wd - in theory is it safe to drive with a dry front diff if in 2wd?
    Thanks so much! I've been a lurker for a while, and the info here has been so helpful :)
  2. Jun 14, 2022 at 2:28 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, spider gears and needle bearings need lube
    SR-71A, Key-Rei and whatstcp like this.
  3. Jun 14, 2022 at 2:29 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not at all
    Key-Rei likes this.
  4. Jun 14, 2022 at 2:30 PM
    j45p3r
    j45p3r Well-Known Member
    Downeast Maine
    2022 MBM TRD Pro 6MT
    Nope. Lots of moving parts even in 2nd.
  5. Jun 14, 2022 at 2:32 PM
    taco330
    taco330 [OP] Member
    Thanks everyone - I couldn't remember if the half shafts and front driveshaft spin in 2wd.
  6. Jun 14, 2022 at 2:35 PM
    TireFire
    Olympic Peninsula
    Half shafts yes, they are connected to your hubs! Front DS no, but it can spin some due to friction.
    if only some oil leaked out your fill port, you’re probably in the clear. Just fill back to spec, snug the bolt and forget about it
  7. Jun 14, 2022 at 2:43 PM
    taco330
    taco330 [OP] Member
    I think this is the case, but will need to check. I guess this is karma for trying to save time and not doing it myself.
  8. Jun 14, 2022 at 2:45 PM
    taco330
    taco330 [OP] Member
    And yeah - this is just me being a noob. There was conflicting info online, and I think the old manual 4wd systems worked by disconnecting the hubs. I wasn't positive if the tacoma hubs had electronic connections or how that worked.
    Thanks for the info! The more you know! :)
  9. Jun 14, 2022 at 2:56 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    No. Always use lube
  10. Jun 14, 2022 at 3:55 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Best to remove the CV axels if you want to try that
  11. Jun 14, 2022 at 4:01 PM
    turbosix
    turbosix Well-Known Member
    dfw
    2024 TRD Pro
    go buy some of those wheel dollies, put em under the front tires and you should be good.
  12. Jun 15, 2022 at 9:36 AM
    taco330
    taco330 [OP] Member
    I think this is the real answer :rofl:
    Thanks again everyone! I'm planning to drain the fluid to see how much was actually in there, then scope it out of paranoia to see if anything went boom. I'm pretty sure nothing got hurt, and I can do the change on my own & be good to go.
