Okay to leave spare flat?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by naked farmer, Dec 16, 2019.
  1. Dec 16, 2019 at 12:55 AM
    naked farmer
    naked farmer [OP] Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Upgrading tires but want to keep spare in stock location. Will it be ok for the spare (305/70 or 295/70) to be kept under the truck partially deflated? The tire will be stuffed under there and won’t be uniformly round. Is that ok for the tire in the long run? I have on board compressor, if I do ever need the spare.
  2. Dec 16, 2019 at 1:00 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I would be concerned about it permanently deforming and making it thumpy.
    No different than parking a vehicle for years sitting on the tires.
    If your okay with only using it in emergency situations and then replacing it with the new tire, then i think it would be ok.
  3. Dec 16, 2019 at 1:43 AM
    oruacat2
    oruacat2 Well-Known Member
    Kenny
    Bluegrass Country
    2017 white Tacoma TRD Offroad
    none yet
    Other than as message board-fodder, what's the advantage of doing this?
    Tullie D likes this.
  4. Dec 16, 2019 at 1:53 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    It won't fit inflated.. the benefit is it fits.
  5. Dec 16, 2019 at 2:15 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    I've seen it done before and I've done it on customers cars that had aftermarket exhaust where the spare was touching the exhaust pipe, so we lowered the pressure
  6. Dec 16, 2019 at 2:37 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Less weight? Dropping to 2 psi vs 35 psi saves a lot of weight. Over the life of the vehicle, this could add up to a lot of gas savings.
    Sorry, I'm joking.
    You won't hurt anything, but I would recommend leaving a little pressure in the tire to make sure the bead remains seated. It would suck to find out you needed that tire but you couldn't get the thing inflated with your onboard air or similar compressor
    TacoMoose likes this.
  7. Dec 16, 2019 at 2:41 AM
    TacoMoose
    2017 Tacoma OR
    thats when you bust out the brake cleaner and start spraying and hope you dont over spray and create a pressure bomb
  8. Dec 16, 2019 at 2:50 AM
    koditten
    Kirk
    Central Michigan
    I still seat the beads that way, it just takes a bigger squirt of spray, since the new stuff is so weak.
