Okay WTF just happened?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IPNPULZ, Jun 4, 2015.
  1. Jun 5, 2015 at 5:58 AM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Aw, come on...that was pretty funny...
    JBecker and kenth123[QUOTED] like this.
  2. Jun 5, 2015 at 6:00 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yeah, it was, and this is TW so you gotta expect a little of this. OP, how does your butthole feel? :D:alien:
    Someone else may need to chime in, but I thought the speedometer and odometer were read at the transmission.
  3. Jun 5, 2015 at 6:03 AM
    kenth123
    kenth123 Well-Known Member
    Kenth
    Norfolk, VA
    13 SR5 Texas Edition
    Pro Comp 6" Lift with front coilovers and rear prorunner socks
    I see that people from Texas have more of a sense of humor. Am I right or am I right?
  4. Jun 5, 2015 at 6:11 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Being these things are no longer straight gearing it is possible, but since this seems isolated it would be difficult to know what could cause it. I would assume if it did it once it will do it again.
  5. Jun 5, 2015 at 6:14 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Your mileage is relayed to ECU and so the true mileage can be read on it which would tell the shop how accurate your odometer reading is. The odometer uses a toothed wheel mounted to the output of the transmission and a magnetic sensor that counts the pulses as each tooth of the wheel goes by. The ECU knows how much distance the car travels with each pulse, and uses this to update the odometer reading. So it may be the output of the ECU or the odometer it self receiving the mileage being screwy
  6. Jun 5, 2015 at 6:15 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    NO.
    nothing happened.
    miles counters on vehicles are regulated by the government. they do not mess up much, but
    Toyota has on occasion had bad combo meters (your dash display) and you might need a replacement
    you are either wrong, trolling us, of have a bad combo meter and need a replacement combo meter.
    the odometer is more reliable at doing it's job and counting miles and keeping them stored (not
    taking about calibration which is the input) on any vehicle than brakes or throttle or airbags....
  7. Jun 5, 2015 at 6:17 AM
    IPNPULZ
    IPNPULZ [OP] Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    This could be correct that the readings are picked up at the transmission as I was just wondering if this could also be picked up at the wheels as well.No butt hurt here!!
  8. Jun 5, 2015 at 6:24 AM
    IPNPULZ
    going to be fun!
    Okay now this makes some sense to me on how the readings are made.
    Another thing I need to look at is about 4 months ago I had a Remote Start/Alarm installed and now I am wondering if maybe some wires have come loose?
    Now another question comes to mind if the Mileage is stored in the ECU and you were to replace that with a aftermarket one that has no history of readings from the vehicle then it would be stored at the cluster right?
  9. Jun 5, 2015 at 6:34 AM
    IPNPULZ
    going to be fun!
    See above post #14!!
  10. Jun 5, 2015 at 6:38 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    This
  11. Jun 5, 2015 at 6:40 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    well
  12. Jun 5, 2015 at 6:44 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    happens to us all :facepalm:
  13. Jun 5, 2015 at 6:45 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I have no experience with the problem you(OP) reported or the folks at the following web site. I suppose it wouldn't hurt to queue up with them and see what they have to say.
    http://modulefixer.com/
  14. Jun 5, 2015 at 6:46 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    dealer would be your best bet
  15. Jun 5, 2015 at 6:49 AM
    #35
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Unfortunately, this being an isolated incident and there are no codes or issues with it mechanically or speedometer readings, it wouldn't surprise me if you get quickly dismissed by the shop and dealer. Please update..
    Lester Lugnut likes this.
  16. Jun 5, 2015 at 6:52 AM
    #36
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Quite a popular thread!
  17. Jun 5, 2015 at 6:52 AM
    #37
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    it's a 2014 so he probably is first owner :notsure:
  18. Jun 5, 2015 at 6:55 AM
    #38
    IPNPULZ
    going to be fun!
    I would hope that if there is a problem with something that caused this the dealer would have this well documented as to what happened so it wont cause any issues.
  19. Jun 5, 2015 at 6:56 AM
    #39
    IPNPULZ
    going to be fun!
    Yep, first owner.
  20. Jun 5, 2015 at 6:58 AM
    #40
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    your ECU has your true mileage so the dealer can easily tell if it is wrong and they can replace the odometer
