OKLEDLIGHTBARS Group Buy #2
Discussion in 'Group Buys' started by Taco Man in HD, May 12, 2013.
Thread Status:
Not open for further replies.
  1. Jun 30, 2013 at 6:48 PM
    #381
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    Finally had a chance to get my lights in the mountains this weekend. I can't see the need for anything more for what I do and for the price, customer service, and quick shipping I'm very happy so far.
  2. Jun 30, 2013 at 7:15 PM
    #382
    andrew8404
    andrew8404 Well-Known Member
    ANDREW
    Albuquerque, NM
    17 DCSB TRD OR 4x4 (Sold) 19 Ford Ranger Sport XLT 4x4
    Sweet the led bar looks good. I should be picking up my bumper tomorrow from powder coating but the light bar cut isn't as big. It still fits the rigid slit but just won't see the top/bottom black part.
  3. Jun 30, 2013 at 7:47 PM
    #383
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    I bought the BAMF led bar brackets to use to mount the 20"
  4. Jun 30, 2013 at 9:25 PM
    #384
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    o
    I think he means that the hardware that came with the light bar is a bit too big to fit through the bamf bracket. Mine was at least. Just pound the screws through with a hammer.
  5. Jun 30, 2013 at 9:27 PM
    #385
    Infra
    Az
    :notsure: I bought that bar during the very first OKLEDlightbar group buy, so what ever hardware that came with it is what I used. You can tell from my sig pic that the newer bars with the cree LED's are significantly brighter
  6. Jun 30, 2013 at 9:58 PM
    #386
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Did that affect the threads at all? I don't want to strip out the threads on the light bar housing.
  7. Jul 1, 2013 at 7:01 AM
    #387
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    If I have to beat a screw through a hole then it will mess up the threads. You can get a nut back on it but it will be very hard from the very first thread. Just get the right size bolts or drill the hole out bigger
  8. Jul 1, 2013 at 7:34 AM
    #388
    hoarder23
    Shay
    NJ
    Scratches
    The problem is that its not a hole its a slot, the housing has a tapped hole and the bolt it accepts is too big for the slots in the LED bar mount for the BAMF behind the grill light bar. I want to be able to adjust the light bar up and down which will require widening the whole slot.
  9. Jul 1, 2013 at 9:32 AM
    #389
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Oooooooooohhhhhhhhhhhhhh, yeah theres no real easy way to widen that whole slot. Easiest way I can think is to take a drill bit bigger then the slot, drill a hole on each end of the slot then use a skil saw and cut a piece out. Or maybe use a drimal and grind the whole slot down
  10. Jul 1, 2013 at 11:08 AM
    #390
    Germ
    Arizona
    2013 TRD OR DCSB
    The nut was just barely larger than my slot so it did not damage the threads when I pounded it through or the the threads on the housing. It did damage the threads on the nuts when I pounded it up and down for adjustments as you mentioned. I can still tighten the bolts down and have no issues though. I only resorted to this method because I don't have the proper tools to widen the slots.
  11. Jul 3, 2013 at 11:22 AM
    #391
    andrew8404
    ANDREW
    Albuquerque, NM
    Sneak peak on my pelfreybuilt front bumper. Still need to find a way to mount the 2x2s.
  12. Jul 3, 2013 at 11:45 AM
    #392
    Infra
    Az
    Bad ass
  13. Jul 14, 2013 at 8:51 AM
    #393
    MattB77
    MattB77 Well-Known Member
    OR
    2013 AC TRD Sport
    Is it possible to still get in on this or is it over? Would like to get the 30 in Combo
  14. Jul 14, 2013 at 9:22 AM
    #394
    Infra
    Az
    This group buy is over, has been for a while.
  15. Jul 14, 2013 at 7:07 PM
    #395
    MattB77
    OR
    2013 AC TRD Sport
    Well fawk!
  16. Jul 14, 2013 at 8:39 PM
    #396
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Here's mine finally all done with my new bumper:
  17. Jul 15, 2013 at 5:08 AM
    #397
    MattB77
    OR
    2013 AC TRD Sport
    Anyone know if there's a possibility of another one in the next couple months
  18. Jul 15, 2013 at 6:13 AM
    #398
    Infra
    Az
    I doubt it. I believe it was a year between his 1st GB and this one.
  19. Jul 15, 2013 at 6:15 AM
    #399
    Infra
    Az
    Just go to his website www.okledlightbars.com
    Purchase one & a wiring harness. Even tho it's not a GB price they are still worth every penny! And his customer service is top notch!!! Chris went out of his way to help me and I can't say enough good things about him & his products
  20. Jul 15, 2013 at 7:26 AM
    #400
    MattB77
    OR
    2013 AC TRD Sport
    I plan on buying one I just figured if I can get a discount I might as well try that route first
Thread Status:
