Old Car BS thread
Discussion in 'Garage / Workshop' started by T4RFTMFW, Apr 18, 2016.
  1. Jul 11, 2017 at 2:03 PM
    #181
    lo1dakota
    lo1dakota Well-Known Member
    Brandon
    Longview, Washington
    2007 Speedway blue double cab TRD off road
    OME K&N Short Thow shifter Pro Comp 16" Wheels Toyo 33" Tires Road Armor Bumpers N-Fab full length bars
  2. Jul 11, 2017 at 2:03 PM
    #182
    lo1dakota
    Brandon
    I agree. Everybody has a 350
  3. Jul 11, 2017 at 8:36 PM
    #183
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    I work for the Brunswick Parks & Recreation Department. We are located at the former fitness center of BNAS, now officially named Brunswick Landing. When were you last stationed at BNAS?
    lo1dakota[QUOTED] likes this.
  4. Jul 11, 2017 at 9:29 PM
    #184
    lo1dakota
    Brandon
    I was in VP-26 and returned from deployment in June of 2010. I separated at the same time.
    ACEkraut[QUOTED] likes this.
  5. Jul 11, 2017 at 9:32 PM
    #185
    ACEkraut
    Aaron
    Durham, Maine
    So you were there right before BNAS closed down. Redevelopment is going well, although it still looks a lot like a ghost town compared to the times when there was a large population stationed there.
  6. Jul 12, 2017 at 6:09 AM
    #186
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    The Flight Deck isn't bad, but their beers are a little spendy for what you get.
  7. Jul 12, 2017 at 7:09 AM
    #187
    lo1dakota
    Brandon
    That sucks. I was concerned that Brunswick/Topsham would suffer from the closure.
  8. Jul 12, 2017 at 8:38 AM
    #188
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    mine was a 350 bored out with some early model camel hump heads
  9. Jul 12, 2017 at 9:30 AM
    #189
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Too sick. Love it.
  10. Jul 12, 2017 at 11:20 AM
    #190
    lo1dakota
    Brandon
    Thanks!
  11. Oct 4, 2017 at 9:29 AM
    #191
    wilcam47
    Will
    Bourbon state
    I saw a 57 fury they other day...in town driving around. It was in need of a paint job but at least it was on the road...
  12. Nov 6, 2017 at 1:09 PM
    #192
    Whizzo
    Whizzo Well-Known Member
    Kansas
    Silver 2017 Limited
    motor.jpg short bus.jpg This is a project I'm working on. 1946 Chevy Short Bus :rofl:
  13. Nov 6, 2017 at 1:52 PM
    #193
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    @Fenwick1993
    We found a better bus for you.
    wilcam47 and Whizzo[QUOTED] like this.
  14. Jan 12, 2018 at 5:42 PM
    #194
    wilcam47
    Will
    Bourbon state
    not really an old car per se but daughters car was giving her fits and running rough, throwing a code for misfire. Changed the coil (no coil packs) and it turns out the spark plug wire is bad/leaking. I would have changed the sparkplug wires first had I heard/seen the faulty wire:goingcrazy::frusty:. I did look briefly look at the wire but I didnt hear it popping so I figured it was good...:mad: should fix with new wires...
  15. Jan 12, 2018 at 6:06 PM
    #195
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    CCE3DA1A-FE00-41C9-BD63-A95495F50A37.jpg Can’t recall the year of this guys Chev. I want to say ‘46?
    T4RFTMFW[OP], Whizzo and Holloman like this.
  16. Jan 12, 2018 at 6:11 PM
    #196
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I like it. I really want to build skirts for my '40. But that will be after I extend my fenders a bit.
    T4RFTMFW[OP] and Steves104x4 like this.
  17. Apr 19, 2018 at 2:37 PM
    #197
    wilcam47
    Will
    Bourbon state
    hey old car guru's, got a question maybe you guys can help. In a 6volt to 12volt conversion is there a 6volt points or 12volt points? Im trying to help a neighbor, on an 8n tractor conversion. The instructions are simple but vague. Looks like they have a 12volt coil but it doesnt mention anything about points or changing them. has about 6volts at the coil across the leads.
  18. Apr 19, 2018 at 8:27 PM
    #198
    windsor
    windsor Just a guy
    Homeless in Oregon
    wilcam47 likes this.
  19. Apr 20, 2018 at 8:42 AM
    #199
    wilcam47
    Will
    Bourbon state
    there is a ceramic resistor, so should it have a 12volt coil also with the resistor? I'll tell them about the electronic ignition.
  20. Apr 20, 2018 at 11:01 AM
    #200
    windsor
    windsor Just a guy
    Homeless in Oregon
    Ignition wire to ballast resistor. Ballast resistor to coil pos. Coil neg to distributor. Distributor to ground.
    With the resistor, there shouldnt be an issue. Tell your neighbor to make sure the points are clean and to check for carbon spikes on the points when servicing it.
    shakerhood and wilcam47 like this.
