Old Car BS thread
Discussion in 'Garage / Workshop' started by T4RFTMFW, Apr 18, 2016.
  1. Apr 20, 2018 at 3:09 PM
    #201
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    thanks! Hopefully it works..
  2. Apr 20, 2018 at 3:17 PM
    #202
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    It should work fine. A true 12v coil doesnt use a resistor but has more windings on the primary side instead. Many that are sold as 12v actually need and use a resistor to drop the voltage down to protect the coil and points.
    When I converted my '40 to 12v (when it had the original motor), I wired it as I described and it ran fine.
    wilcam47 likes this.
  3. Apr 20, 2018 at 3:21 PM
    #203
    wilcam47
    Will
    Bourbon state
    Its been a long while since Ive messed with points ;) Surprising lots of people havent even messed with them at all...
  4. Apr 20, 2018 at 3:32 PM
    #204
    windsor
    windsor Just a guy
    Homeless in Oregon
    Yep. With the low cost and ease of electronic breakerless conversions, points will be mainly for oddball vehicles and purists.
    There are also conversion kits to put a 302 in an 8n.
  5. Apr 20, 2018 at 3:33 PM
    #205
    wilcam47
    Will
    Bourbon state
    wow, that would be crazy...bet it could pull a stump quite easy;)
  6. Apr 20, 2018 at 3:56 PM
    #206
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    My 2nd to last boat was early 80's vintage Grady White with a 350 SBC setup that used points.
    I think Mercruisers used points well into the mid 80's.
    I never had issues with points and always carried spares. If they did hose up, you can always slap a new set in and gap it with a matchbook cover, lol. Easier to get out of a jam on the water than running a transistor ignition, when blown ,would leave you stranded.
    wilcam47[QUOTED] likes this.
  7. Apr 20, 2018 at 6:35 PM
    #207
    wilcam47
    Will
    Bourbon state
    what measurement is the matchbook?
  8. Apr 21, 2018 at 2:27 AM
    #208
    bucktales
    around .016-.020 , and that's where you want to be with points.
  9. Apr 21, 2018 at 7:15 PM
    #209
    wilcam47
    Will
    Bourbon state
    well got some progress, got spark and now its a fuel problem. ah the joys of old equipment!;) Have to try and adjust the carb, tried initially what the book says but it seemed like it was flooding it.
  10. Apr 22, 2018 at 5:13 AM
    #210
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    We need a tractor thread
  11. May 21, 2018 at 6:44 AM
    #211
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    Spent Saturday afternoon chasing electrical issues on the '69. Dash lights haven't been working, so I replaced the fuse (which had blown). Popped it again as soon as I turned the headlights on. All of the gauges were still working fine, so I've been putting it off (because I hate chasing electrical problems, lol), but a rainy Saturday seemed like the perfect opportunity to hide in the garage and rip my dashboard apart :rolleyes:
    3 hours later, after tracing every wire from the engine bay to the fuse box, from the fuse box to the switch, and from the switch to the dash looking for cracked insulation, frayed wires, burnt fusible links, etc. I was able to find the problem and fix it.
    The back side of the dash panel on this truck is made of aluminum, and is grounded to the chassis. The dash lights are supplied by individual 'hot' wires that come into crimp connection in the bakelite fitting that contacts the base of the bulb, and the retaining pieces for the fitting complete the circuit against the grounded dash panel housing. Turns out that one of the crimp connections (circled below) hadn't been tight enough at the factory, and after 49 years of vibration the wire had worked its way loose and welded itself to the negatively charged bulb housing. So every time power was supplied to that circuit it shorted and popped the fuse. And since it was inside a bakelight cover, of course you couldn't see it unless you actually pulled the bulb out of the fitting and looked at the wire :frusty:
    3 hours chasing wiring for a 10 second fix :rolleyes:
  12. May 21, 2018 at 9:27 AM
    #212
    wilcam47
    Will
    Bourbon state
    thats like the fusible links...whoever thought that up needed to get slapped with a cinderblock...
  13. May 21, 2018 at 9:31 AM
    #213
    Noelie84
    Noel
    Wales, Maine
    Pretty much. Just make it an inline fuse; you can tell at a glance if it's toast.
  14. May 21, 2018 at 9:34 AM
    #214
    wilcam47
    Will
    Bourbon state
    I think that was the "idea" with fusible links but when the plastic doesnt melt you cant find the problem...LOL guess they didnt think of that;)
  15. Feb 7, 2019 at 10:34 AM
    #215
    TacosOnTheBeach
    TacosOnTheBeach Member
    Here's what I'm working on right now. It's a 1963 Mercedes 190Dc. Currently rebuilding the front end and the entire brake system.IMG_20181015_102126.jpg IMG_20181015_102151.jpg IMG_20181015_102218.jpg
  16. Apr 24, 2019 at 5:28 PM
    #216
    T4RFTMFW
    T4RFTMFW [OP] Well-Known Member
    I finally ordered a 4 link, step notch and airbags for the rear of my 49.
    shakerhood, buyobuyo and wilcam47 like this.
  17. May 10, 2019 at 8:50 AM
    #217
    wilcam47
    Will
    Bourbon state
    I think of this when I have to help people do basic maintenance on their vehicle....such as change brake pads and rotors...
    T4RFTMFW[OP] likes this.
  18. Sep 15, 2020 at 5:08 PM
    #218
    Djaemac
    Djaemac Well-Known Member
    Jae
    2001 Tacoma TRD, Lamborghini Gallardo, Tesla Model S, Porsche Cayenne S, Mercedes SL55, BMW M3 supercharged
    Any update on this? Love to see the progress on this build
  19. Oct 24, 2023 at 8:28 PM
    #219
    BTWNaRock&aHardplace
    BTWNaRock&aHardplace Well-Known Member
    DW
    47°47’47”N 123°41’41”W
    2022 TRD
    a cb radio and 2 baby seats
    Bump! I used this to get parts for my Tacoma once. Can't tell ya how many times I've done the reverse over the years?!
    Spintly and LarryDangerfield like this.
  20. Jan 1, 2024 at 11:34 AM
    #220
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    A bored and milled 292 would be a great substitution.
