Old gas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Thunderbucket2000, Jan 29, 2025.
  1. Jan 29, 2025 at 2:25 PM
    Thunderbucket2000
    Thunderbucket2000 [OP] Member
    1995 Tacoma 4x4 5-spd
    I bought a’95, with the V6, and it only has 69k miles on it.
    It has a little more than half a tank of old gas in it (about 3 years old). I just need to plug in a new battery, and it should be fine.
    My question is, should I drain the old gas from it, or should I just dilute it with some new gas. Maybe high octane? I just don’t want to cause any problems with such a nice old truck.
    Thanks for your input
  2. Jan 29, 2025 at 2:28 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Have you driven it home yet?
    I mean “taken possession of her”
  3. Jan 29, 2025 at 3:07 PM
    ControlCar
    Steven
    Sugar Land TX
    Well
    Regardless
    The latest car program I have been watching Roadworthy Restorations
    Derek routinely uses(fails sometimes) at least to start/limp the vehicle sitting for 40yrs….to his shop
    I would dilute (like u stated) with some new fuel…maybe add couple bottles of Techtron or similar
    But once at home
    100% change FF
    Thunderbucket2000[OP] likes this.
  4. Jan 29, 2025 at 3:20 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Fill it with new gas and run it. I've run a car with 5 year old gas in it and couldn't even tell
  5. Jan 29, 2025 at 3:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    *Roadworthy Rescues on Motor Trend
    Great show, and he's pretty funny if you like Southern humor. Dear 'ole Dad would have loved the show and working along side him.
    @Thunderbucket2000 I've drug stuff home and started it with a Coke bottle of gas in the carb. And most had been sitting a good while.
    These days I'd be a smidge more cautious. *I'd* use 2 bottles of Techron, 2 bottles of Sta-Bil 360, fill it with premium gas and cross my fingers.
    Hoping for you it runs well and hasn't be sitting so long all the rubber bits on everything are rotted off, the brakes aren't frozen and it's been out of the weather.
  6. Jan 29, 2025 at 10:06 PM
    Thunderbucket2000
    I love watching Derek getting all of those old cars running.
    I have no doubt that I could pour some new gas in it, and a bottle of berryman’s, or techron, and it would run. I’m just wondering about potential problems in the future.
    Most of the stuff that he is driving is junk, and the goal is just to get it to run. I want this truck to live a long, healthy life.
  7. Jan 30, 2025 at 6:03 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Water may be your only enemy. A bottle of water fix it (winter whatever its called)
  8. Jan 30, 2025 at 6:39 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    If it the engine will run off the old gas I would just try to burn all of it through the engine and fill the tank when it gets low. It might run rough until it has fresh gas so I wouldn't bother with trying to troubleshoot engine issues until you get some fresh gas in it. If it won't run on the old gas then I would try to siphon it or get it out somehow.
    My bet is it will run on the 3 yr old gas, probably not great though.
  9. Jan 30, 2025 at 6:50 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    At 69K I personally would drain most of it and use it for lawn mowers. As mentioned though, some gas stabilizer and fill it up with fresh gas and you're probably fine. Good find! Mine had 63 on it when I bought it.
  10. Jan 30, 2025 at 8:11 AM
    Glamisman
    Glamisman Well-Known Member
    If it is a CA truck, drain it. The gas out here doesnt last 6 months before it turns to shit.
  11. Jan 30, 2025 at 10:23 AM
    Thunderbucket2000
    It’s a NM vehicle. Virtually zero humidity, or even precipitation, ever
  12. Jan 30, 2025 at 2:30 PM
    ControlCar
    Steven
    Sugar Land TX
    you will be golden with the advice posted
  13. Jan 30, 2025 at 8:22 PM
    wingnutj468
    wingnutj468 Well-Known Member
    David
    2003 gold doublecab 4x4 2.0
    Stick a siphon hose in it and get as much out as you can. The peace of mind will be more than worth the effort. Use the old gas on some pesky ant piles. Move “new fuel filter” a few notches higher up on your to do list.
