Old injector tips left behind. Should I just remove the manifold?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ChargedTaco99, May 14, 2025.
  1. May 14, 2025 at 4:37 PM
    ChargedTaco99
    ChargedTaco99 [OP] Member
    1999 White Tacoma, TRD, Supercharged
    Working on my fuel injectors. All 6 easily came out/stayed in the fuel rail and left their tips behind. I started with the cylinder 5/newest one and it is breaking. Do i just remove the manifold and knock them out the other way at this point? Other ideas?
  2. May 14, 2025 at 4:52 PM
    ChargedTaco99
    I took my truck to the shop for the knock sensors las fall. I wonder if they just threw the injectors back in after the tips came off like that...
  3. May 14, 2025 at 5:42 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    The rubber grommet on end of the injector sometimes stays in the manifold
    Not a problem
    can’t see the injector that broke/cracked though
    I used a pick or angled awl to get the grommet out…..shop vac would help get loose bits out as well
  4. May 14, 2025 at 5:59 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    should have sprayed the base of the injectors with a lubricant prior to removing, would have helped along with careful manipulation....
    some tips appear to be broken & debris fell in im assuming....
    #3 in back left corner...
    the others will just pick out, spray them....
    the oring sticks..
    ControlCar likes this.
  5. May 14, 2025 at 8:30 PM
    ChargedTaco99
    UPDATE: I got advice from a mechanic friend to just go ahead and take it off.
    Had some success.
    and a new, bigger problem
    Any advice for screw extraction from the block?
  6. May 14, 2025 at 8:34 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Knee deep now. Heat, PB blaster, a good extraction set. Worse case is drill perfectly center if all else fails. Worse case after that is a time cert.
    LOLLY likes this.
  7. May 14, 2025 at 8:55 PM
    Glamisman
    Glamisman Well-Known Member
    If you have never done this before take the head off and take it to an auto machine shop. The simple job of injectors could turn to a cylinder head replacement REALLY fast. The next dilema is if you take the head off and you look at the valves and you dont like what you see, do you take the other head off and have the valves done, this is mission creap at its worst. The silver lining is that you arent paying someone $175 hour to do it, look at all of the money you are saving...
    ChargedTaco99[OP] likes this.
  8. May 14, 2025 at 9:17 PM
    ControlCar
    Steven
    Sugar Land TX
    Ouchy.
    what worries me is that ‘band’ that starts at 11 O’clock. Not a clean break
  9. May 14, 2025 at 9:26 PM
    ControlCar
    Steven
    Sugar Land TX
    IMG_6561.jpg I snapped a valve cover bolt on a EJ25
    The bolt was on bottom
    I had to remove motor mounts
    Drop engine onto subframe
    Notched subframe
    Notched
    R angle drill housing
    Just to get clearance to attempt
    Was my 1st time doing a bolt extraction
    same boat as you, fucking it up meant
    Engine out/new head or helicoil
    I kept the bolt as a trophy
  10. May 14, 2025 at 9:28 PM
    ControlCar
    Steven
    Sugar Land TX
    Mine was a clean flat break
  11. May 14, 2025 at 9:35 PM
    ControlCar
    Steven
    Sugar Land TX
    Good thing
    You have plenty of room
    bad thing
    Your break not clean
    Manifold bolt larger
    Mech told me to use expensive drill bit(I did). Not the opo side of the reverse threaded extraction kit
    just remember a mistake here will be expensive
  12. May 14, 2025 at 9:56 PM
    ChargedTaco99
    Thanks for the input ControlCar. I have a few years of general/college machine shop experience just very little mechanic experience. I definitely plan to get a carbide or good high-speed steel bit and be very carful. Will try to set my center with a punch and center drill first. Ya if I miss and go into the cylinder head ... time cert indeed. Thanks guys, I'll keep you posted how it goes.
    Any ideas on where to get replacement hardware?
  13. May 14, 2025 at 10:04 PM
    ControlCar
    Steven
    Sugar Land TX
    Spot on plan
    Carbide bit
    Center punch the shit out of that bolt
    High quality extraction set
    I would clean up the remaining portion of bolt with dremel too
    Once i knew that drill hole was centered, I almost doubled the depth of “what I thought” would be deep enough.
    Was thinking…..I got one chance at this
    after that is done…..would definitely plumbers torch the area for min or two
    GL!!!!
    Wulf likes this.
  14. May 18, 2025 at 1:19 PM
    ChargedTaco99
    Update. Thoughts on boring it out and going up to a 10mm? Broke an extractor off. I will try to grind it out, then step up in drill sizes until I can pick the bolt threads out. I fear I am highly likely to blow out the threads on the aluminum head when I do that though. Currently an M8x1.25
  15. May 18, 2025 at 2:17 PM
    ChargedTaco99
    Got it ground down far enough that I could chase it with a carbide bit now… probably just grind it all the way out though.
  16. May 19, 2025 at 8:22 PM
    ControlCar
    Steven
    Sugar Land TX
    That 1st pix looks good as far as depth of hole
    Don’t forget lil heat
    Once tape starts shriveling, don’t heat too much more
  17. May 21, 2025 at 9:09 PM
    ChargedTaco99
    Many hours of slow dremel, drill, and tap activities later… The stuff of dreams! We’ll see if the original threads are strong enough for the bolt tomorrow!
  18. May 22, 2025 at 4:08 PM
    ControlCar
    Steven
    Sugar Land TX
    great job!!
    IMO
    Those threads won’t hold….could get tight but then .003 of a twist too much, will strip
    Too important of a engine component to have “less than tight”
    try using a Heilcoil
    Typically once installed, stronger than original fastener
    once correct heilcoil size bought($15-20)
    Extra 1hr needed to install
    And piece of mind
    lemme see if I can find my HC kit I used on a Honda head…..
  19. May 22, 2025 at 4:13 PM
    ControlCar
    Steven
    Sugar Land TX
    Found it
  20. May 23, 2025 at 10:22 AM
    SpencerTacoSC
    SpencerTacoSC Well-Known Member
    Daniel
    2004 Tacoma 4x4 V6
    Absolute minimum run a blind tap down those threads to clean them up.
