Old Man Emu BP51
Discussion in 'Suspension' started by Camel51, May 17, 2016.
  1. Jan 29, 2017 at 6:19 PM
    #121
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Yeah I'm getting either BP 51s or Fox shocks in a few weeks.
    I live in the rust belt so I'm thinking the BP 51s, they have rebound adjustment, by pass and "better" corrosion protection.
    No one seams to be complaining about them and everyone seams to like them.
  2. Jan 29, 2017 at 6:24 PM
    #122
    PNW/TRD Steve
    PNW/TRD Steve Well-Known Member
    WA
    2012 DCSB TRD
    ImMrYo Rear view mirror lift bracket. Changed out mud flaps. Salex glove box organizer. OEM Ashtray (cup). AVS Step Shields. 16x8 SCS F5 Matte Jet Black. 265/75 16 Cooper St Maxx. OME Bp-51s. U.S. Offroad Winch Mount (in process) Smittybuilt x20 12k synthetic winch (in process) More....
    Unfortunately, I never took measurements. To me it looked like I got three inches in the front and two and a half inches in the back. That made the truck sit level. I had to install in June. I can guess maybe eight thousand miles since. I would guess it's settled about a quarter of an inch. I've got some pictures on my build post. And I've done some short reviews on a couple of the BP-51 threads.
  3. Jan 29, 2017 at 6:26 PM
    #123
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Thank you sir.
  4. Jan 29, 2017 at 6:31 PM
    #124
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Just my .02, but the BP51 I believe is not a true midtravel, and limits downtravel. I'm sure they ride ok, but for the price, I'd go King any day.
  5. Jan 29, 2017 at 6:37 PM
    #125
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I drive a double cab long bed, not sure I will find a situation that will be a make or break with an inch less down travel up front.
    mutilatedjak likes this.
  6. Jan 29, 2017 at 8:05 PM
    #126
    Camel51
    Camel51 [OP] Well-Known Member
    Colorado
    2006 DCSB TRD-Offroad
    OME BP51's, Brute Force Fab, BFG KO2's
    I've been overseas for awhile and haven't been driving much lately. So I can't really comment. Slight adjustments make a noticeable difference and I really like the performance. I'll be picking up my truck in a few weeks and putting on steel bumpers and rock sliders. I'll let you know what I think then though you should have purchased yours by then).
  7. Jan 29, 2017 at 8:22 PM
    #127
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Did you install a diff drop?
  8. Jan 30, 2017 at 3:38 AM
    #128
    Camel51
    Colorado
    No, just a carrier bearing drop kit.
  9. Jan 30, 2017 at 5:08 AM
    #129
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Thanks
  10. Feb 11, 2017 at 5:15 PM
    #130
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    My BP's and uca's show up on Monday. The question is do I leave them at factory preload or not. I have 60#'s of skids and about 120#'s of rock sliders to install as well.
  11. Feb 11, 2017 at 5:39 PM
    #131
    rockhopjohn
    rockhopjohn Well-Known Member
    ID, MT, ND, I'm a transient
    2013 Tacoma T|X Baja
    I started a thread for people to post what their set ups are here: https://www.tacomaworld.com/threads/what-do-you-have-your-ome-bp-51s-set-at.474525/
    I am in a similar situation to you. Mine should be in Wednesday, and I wanted to get them set right before I installed them. They come pre-set with 20mm of preload. When I called ARB, they recommended 10mm for a totally stock truck. In my case with my aluminum plate bumper and steel skid, I am about 80 lbs over stock. My plan to probably set them to 12mm. For reference, they recommend 15mm for a full steel plate bumper, but no winch or armor. The 20mm out of the box is for steel plate bumper, winch and skids. All of these set ups are supposed to give about 2" of lift. The 20mm on a stock truck can give as much as 3-4" of lift based on some reports.
    Camel51[OP] and TACOVRD like this.
  12. Feb 11, 2017 at 5:41 PM
    #132
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Thanks, I check it out.
  13. Feb 12, 2017 at 10:39 AM
    #133
    shr133
    Muskego, WI
    2010 V6 Sport
    I wonder if the icon spanner wrench works?????
    http://www.headstrongoffroad.com/store/p42/Icon_Spanner_Wrench_-_198000.html
    Someones spanner wrench must work...
  14. Feb 12, 2017 at 10:41 AM
    #134
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    ^^^ Good info!!! Thx!
  15. Feb 12, 2017 at 10:42 AM
    #135
    rockhopjohn
    When I talked to ARB they strongly recommended doing the adjustments with the spring compressed. They said the threads were not designed for making adjustments while the ring is under pressure, and that you run a serious risk of messing up your threads. I am sure you can find a tool to to turn the ring, but for me, its not worth the risk.
    Camel51[OP] and shr133[QUOTED] like this.
  16. Feb 12, 2017 at 10:45 AM
    #136
    shr133
    Muskego, WI
    2010 V6 Sport
    That's why they don't include a spanner wrench......
  17. Feb 12, 2017 at 10:51 AM
    #137
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
  18. Feb 12, 2017 at 8:11 PM
    #138
    Camel51
    Colorado
    It came with two. They both do the same thing, which is adjusting the compression and rebound on the shock.
  19. Feb 12, 2017 at 8:14 PM
    #139
    Camel51
    Colorado
    Good to know. My dad just took my truck to the fab shop and got my bumpers and sliders put on for when I fly back. I pick it up next week and will check out the measurements.
  20. Feb 12, 2017 at 8:16 PM
    #140
    tacoma08brandon87
    tacoma08brandon87 Well-Known Member
    brandon
    El Paso Texas
    TRD
    Let me know how you like those leaf Springs old man emu leaf Springs.
    Camel51[OP] likes this.
