Old man Emu - Dakar leaf pack vs. AAL
Discussion in 'Suspension' started by Pjf1119, Apr 27, 2016.
  1. Apr 28, 2016 at 8:22 AM
    TacoSeanFF
    TacoSeanFF Well-Known Member
    Sean
    Colorado
    2016 Inferno Taco TRD OR
    3" OME Lift, 885 coils, Dakar leaf pack, 285/70/17 Hankook Dynapro ATM on 17x7 TRD wheels, mod painted grill, dipped badges, black rear fender decals, bed extender, privacy tint
    I went with SPC UCA's. My wheel offset is 11mm with the sema TRD wheels. I'm waiting until my shop sets my caster forward to see if I need to do a CMC. Already looked into the forums for that though. I'll update after I get it aligned next week
  2. Apr 28, 2016 at 11:43 AM
    MeFryRice
    MeFryRice Well-Known Member
    Marietta, Ga
    '16 QS Tacoma DCOR4x4
    I'm running the Total Chaos UCA. The wheels are 16x8 et0 although I am not sure what the back spacing #'s are as I have not measured them. They do rub the cab mount slightly which I will be trimming when I do the rear shock relocation setup in the next couple weeks.
  3. Apr 28, 2016 at 2:14 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    @TacoSeanFF , @MeFryRice
    Thanks for the feedback, not sure why some owners are getting away with no rub, (with 285r16 let alone 285r17) seems like you need a good alignment tech to give you the caster that you need to move forward (positive caster?) out to the limits --->maybe no chop, Both UCA's are excellent...have nothing but good in feedback in the forums.
    I myself have been trying to pull back the reigns on another $500 for UCA's unless I absolutely need them, gives you that flexible geometry you need for a "good" alignment depending on how much you lift...
    I am looking for that 2.5" settled in lift and with that I do not think I will need new UCA's.... all the experts can chime in here....:fingerscrossed:
    Anyhow rides look awesome not sure of your suspensions, but I am sure you both have excellent components.
    BTW going with the DAKAR/EMU package, considering 886or 887 coils.
    Enjoy!
  4. Apr 28, 2016 at 3:00 PM
    nizzmont
    nizzmont Well-Known Member
    Brian
    S.E WA state
    2015 doublecab TRD sport
    in progress
    I went with OME setup with 887 and did the UCA's as well,read that going for a full 3 inch its the best way to go
    arkywally likes this.
  5. Apr 28, 2016 at 4:42 PM
    arkywally
    David
    2016 DCSB TRDOR
    Gotta respect that @nizzmont did you do the Dakar Pac or other?
    I really like the kings, Boss, Icon, but OME just seems economically solid especially if you want the Dakar pac...in the package or not.
  6. Apr 28, 2016 at 4:56 PM
    nizzmont
    Brian
    S.E WA state
    in progress
    Yeah full leaf packs seemed to be the best way to go for me since I have 80k on 2008 suspension it's time to replace so why not upgrade it all
  7. Apr 28, 2016 at 4:58 PM
    rvdb
    rvdb Well-Known Member
    CA
    TRD Sport
    stuff that makes it better for my use...
    Replying to the sag question, I am running the All Pro expo pack on a long bed with a shell, full bed slide and about 300 pounds of tools for over 2 years and I would say visually they have not sagged. If you go with the Expos make sure you have weight in your truck otherwise go with the regular ones.
    Mademan925 likes this.
  8. May 27, 2016 at 5:58 PM
    kanoaml
    kanoaml Well-Known Member
    2001 Toyota Tacoma
    I am looking at toytec BOSS suspension for my 1st ten. If I set coils to 2.5-3" in. of lift and slap on the dakar leaf packs for my 01' will it level the truck/have rake in the back? I don't want to run blocks and am hoping to not have to buy shackles. Thanks!
  9. Jul 6, 2016 at 12:43 PM
    ProfessorX
    ProfessorX Well-Known Member
    Jimmy
    Menifee, Ca.
    2001 4DR TRD 4x4(sold) 2016 DC SB TRD OR 4x4(totaled)
    Looks good. I'm looking to pull the trigger on the dakars, how does it ride without weight in the bed? What's your setup in the front? THanks!!!
  10. Jul 6, 2016 at 1:11 PM
    Pjf1119
    Pjf1119 [OP] Well-Known Member
    Ended up going with the Full OME Dakar set in the rear with billstein 5100's, Kept the iron-man Springs and shocks in the front and wrapped the factory rims in Nitto Terra Grappler's 285/75/16 D's. All work was completed at SoCal Suspension in El Cajon San Diego and I could not be happier with the way the truck came out! My Tacoma rides beautifully.
  11. Jul 6, 2016 at 6:46 PM
    MeFryRice
    Marietta, Ga
    The leaf pack was pretty stiff at first but have since "soften" up after putting some mileage on them. I plan to add an RTT to the bed so I'm sure they'll ride even better once weight is added. Right now, I do not carry anything in the bed on a daily basis.
    For the front suspension, I'm running the King extended travel coilovers with TC UCAs.
    ProfessorX[QUOTED] likes this.
  12. Jul 6, 2016 at 9:39 PM
    ProfessorX
    Jimmy
    Menifee, Ca.
    Thanks!
  13. Jul 10, 2016 at 7:47 AM
    carRamRod
    carRamRod Hood Rich
    Dustin
    Milwaukee
    Pics!
  14. Jul 11, 2016 at 9:04 AM
    Pjf1119
    I just removed the rag top and will have to post a few more from different angles when i get some time.
    carRamRod likes this.
  15. Jan 19, 2017 at 3:48 PM
    #35
    Pjf1119
    I'll be buying an aluminum shell and loading the truck up for the cross country trip - we'll be on the road for 3-4 weeks, does anyone recommend adding in an extra add a leaf?
    Total load should be between 400-500 lbs.
    Thanks!
  16. Jan 19, 2017 at 3:51 PM
    #36
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Dakars with an AAL for that kind of constant weight.
    Sna likes this.
  17. Jan 19, 2017 at 3:53 PM
    #37
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    curious what are your guys measurements from center hub to fender with your Dakars?
  18. Jan 19, 2017 at 3:57 PM
    #38
    Pjf1119
    rough measurement last night was roughly 25 3/4''
    Thanks i'll look into the additional leaf cost at my local spring shop. Any ideas on price points?
  19. Apr 14, 2017 at 12:01 AM
    #39
    TRDPugz
    TRDPugz Instagram @trdpro_pugz
    dimitri
    2017 White Tacoma TRD Pro
    that's pretty much the set up im going for right now, do you happen to know your front thread count after you leveled them out, i want mine to be leveled once I get the Dakars,
  20. Apr 14, 2017 at 5:57 AM
    #40
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    ^^^ Yup....I'm installing the AAL in my pack in preparation of getting skids, sliders and rear bumper with fuel/tire swing out a few months after the lift goes in. I don't want to take things apart again so the truck will be a little ass high for that time.
