Old Man Emu Front End Clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Aug 17, 2018.
  1. Aug 17, 2018 at 9:23 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    5100s w/ 2887s from arb. Getting a clunk from just the passenger side while offroad or hitting a larger size bump or small pot hole on the road. I have gone through every nut and bolt to check torque and there all good to go. Anyone else have this issue going on?
  2. Aug 17, 2018 at 9:27 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Have you looked at spring/UCA clearance throughout entire travel? Might be spring/UCA contact or similar.
  3. Aug 17, 2018 at 9:30 PM
    757yotas
    Virginia
    2007 TRD Sport
    I have and i already have aftermarket UCAs. There is still a small amount of room at full droop at least to my eye. Is there any way to for sure tell? Like some sort of paint test or something?
  4. Aug 17, 2018 at 9:48 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    How long have you been running this setup and has it made this noise since installing or is it a new thing.
  5. Aug 18, 2018 at 8:13 AM
    757yotas
    Virginia
    2007 TRD Sport
    It has been on for a few months. Never noticed the sound at first
  6. Aug 18, 2018 at 8:17 AM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I had a similar issue for a minute, and it ended up being the swaybar bushings.
  7. Aug 18, 2018 at 8:19 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's most likely the shock getting fully extended and topping out. It doesn't happen when you hit the bump, but happens right after when the wheel is traveling downward. It just gets fully extended for a split second and the noise you're hearing is the internal limiter. You'd probably hear it over aggressive speed bumps as well.
    rollin904 likes this.
  8. Aug 18, 2018 at 8:23 AM
    GDT
    I've heard about the arb shocks clunking before, but why would your shock be topping out during speed bumps and potholes. When you hit a speedbump, the shock compresses and then rebounds to ride height. Why would it top out in that scenario?
  9. Aug 18, 2018 at 8:25 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Because it rebounds past ride height and to full extension. It really only happens when hitting large bumps quickly. It's hard to explain, but it makes sense in my head, and many established vendors say the same thing as me.
    13txtaco likes this.
  10. Aug 18, 2018 at 8:29 AM
    GDT
    That's only going to happen if the bump was big enough that the suspension couldn't completely absorb it and it sends the truck up, or the backside of the bump drops away. In the speedbump scenario, the shock isn't going to top out.
  11. Aug 18, 2018 at 8:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Don't know what to tell you, but I have personally experienced this happening to me, as well as a lot of other people on this forum because this suspension is very common.
  12. Aug 18, 2018 at 8:32 AM
    GDT
    Ok, well if you and a lot of other people are topping out your shocks on your aftermarket off-road suspension while going over speed bumps, then I don't know what to tell you.
  13. Aug 18, 2018 at 8:39 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    ¯\_(ツ)_/¯
    hammertaco11 likes this.
  14. Aug 18, 2018 at 10:39 AM
    757yotas
    Virginia
    2007 TRD Sport
    I have 5100s and only the passenger side does it though?
  15. Aug 18, 2018 at 10:42 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When I had 5100/885 coils it only happened on the passenger side as well.
    757yotas[QUOTED][OP] likes this.
  16. Aug 18, 2018 at 11:16 AM
    tomtom
    The Desert SW
    2012 FJ
    My experience on a 1st Gen OME setup, it would be very obvious. Since you mentioned you have aftermarket UCAs, probably not the culprit then. That is how I solved my clunk.
  17. Aug 18, 2018 at 11:59 AM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Are you running a swaybar and if so did you install the swaybar relocate?
  18. Aug 18, 2018 at 12:01 PM
    757yotas
    Virginia
    2007 TRD Sport
    I am, i have new end links but no relocation bracket. It does not look like it is physically possible for it to be hitting the coil seat or shock?
  19. Aug 18, 2018 at 12:12 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I have the OME nitro shocks with 885's and only the passenger side gives me that clunk when hitting bumps or potholes. I had no swaybar when I got the truck, so I know it's not that. I have the swaybar now with the drop brackets and it's no different. I also have the SPC UCA's. Seems like quite the coincidence that it's the passenger side and 5100's and nitros as well. I know it happens when I have a passenger.
    EatSleepTacos likes this.
  20. Aug 18, 2018 at 12:29 PM
    757yotas
    Virginia
    2007 TRD Sport
    It seems like alot have this issue, hard to believe it is so hard for this to get solved :notsure:
