Old Man Emu Lift
Discussion in 'New Members' started by PNW, Aug 23, 2013.
  1. Aug 23, 2013 at 9:06 PM
    PNW
    PNW [OP] Active Member
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    Do I need an alignment after I do the whole setup?
    Here is a picture of what I'm doing. This isn't all the equipment I have though, but it is the main parts.
  2. Aug 23, 2013 at 9:08 PM
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
  3. Aug 23, 2013 at 9:10 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    Get some UCA while you're at it. Don't be like me and pay for an alignment twice.
  4. Aug 23, 2013 at 9:15 PM
    FlexIT
    FlexIT You can't polish a TRD
    Nick
    North Pole, AK
    It's shiny??
    Nice kit you got there! I'm looking at getting the same. What coils you got? ^^^I agree should look into getting some UCA's.
  5. Aug 23, 2013 at 9:27 PM
    dira1987
    dira1987 Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    I would recommend an alignment for sure. Since you will be replacing the front shocks/coils it will need to be put back into spec
  6. Aug 23, 2013 at 9:32 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Mine couldn't handle a curve at 5MPH without squealing after I got my OME lift. Alignment will be a must.
  7. Aug 23, 2013 at 9:34 PM
    PNW
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    They are 882 coils for my 2000
  8. Aug 23, 2013 at 11:23 PM
    danstruck
    danstruck Member
    dan
    ocoee, florida
    06 tacoma 5spd 4wd 2.7, ome 3inch lift
    hard bed cover, step tubes
    i out the ome 3 inch kit with the 885 springs on my 06 access cab about 4 months ago. alingment is a must. havent done uca yet due to money. it lines up pretty close but the tire will wear on outside alittle due to too much camber, still very good ride tho.
  9. Aug 24, 2013 at 11:29 PM
    PNW
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    I was just wondering because I wanted to install it myself then just take it in to get aligned, but I live 30 minutes from an alignment shop. Would that be to far to drive it before it gets aligned?
  10. Aug 24, 2013 at 11:42 PM
    Mikehole
    Mikehole Well-Known Member
    SF Bay Area
    '12 4x4 Short Bed TRD Off Road
    TRD Supercharger, Toytec 3" Ultimate Lift w/ 285/75/16s and planning on OBA for sometime in the future. Also thinking about the HWMS and a Warn 8000 for it.
    I think it would be ok. You're not going to wear out the tires significantly in that distance. IIRC, the specs for the lift require that you drive ten miles (or something small) and recheck all the torques on the bolts. That would be the primary concern for me.
    While you're driving, just don't go crazy 80mph around corners on the way there. Take it easy and you'll be ok.
    I think. :
    I did the same thing (installed myself and drove to an alignment shop) and I had no issues.
  11. Aug 25, 2013 at 6:28 AM
    PNW
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    Thank you! Now I just need to get the time to do it
  12. Aug 25, 2013 at 7:18 AM
    PNW
    Nick
    Cle Elum, WA
    2000 4x4 TRD SR5
    Full OME lift kit!
    What are the torque specs for a 2000? I have searched and can't find anything
  13. Aug 27, 2013 at 11:41 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Welcome
    I would ask your questions in the suspension or tech threads.
    U will get tons of advise
