Old man Emu rear leafs??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HDFD10, Feb 27, 2010.
  1. Feb 27, 2010 at 8:12 PM
    HDFD10
    HDFD10 [OP] Well-Known Member
    Hey guys. Have an '06 with a 2.5 leveling kit up front and an AAL in the rear. I need more hauling capacity out of the thing. The AAL helped but i swear i can throw a couple hundred pounds of camping stuff in back and it sags and rides like hell going down the highway. Now i was told by a local shop that the 3" old man emu springs are a 7 leaf pack and will increase my load carrying capacity. So for you guys running these springs how are they.? Is it worth the $320.00 they want for the springs? Thanks a ton!!
  2. Feb 27, 2010 at 8:40 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    your rear end is sagging and bottoming out because you need the 'TSB". search tsb in the search menu it will tell you all about it
  3. Feb 27, 2010 at 8:44 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    TSB is no longer applicable due to the fact he's out of the 3yr/36k warranty
  4. Feb 27, 2010 at 8:52 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    its 320 per side-look at toytecs website, u will probably need more than the leaf springs, you will need u bolts, carrier bearing drop, etc, someone knows about this more than i do
  5. Feb 27, 2010 at 8:53 PM
    luni
    luni Resident Gun-toting Hippie
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    Icon c/os, TSB 4 leaf pack, Unbreakable Fab tube winch bumper, Mile Marker SEC12000, Roadless Gear winch control panel, Bud Built skids, URD Pipe Bomb Y pipe, snorkeled rear diff breather, no carpet
    TSB would effect load carrying capacity about as much as an AAL would I'd imagine. Both just add an extra leaf.
    Having run a dakar leaf pack and TSB rear leafs the dakar pack was better all around. The TSB was cheaper (free). If I get around to overhauling the suspension on my 09 I'll be getting another dakar rear leaf pack to hold all my camping equipment and possibly a trailer.
    U-bolts (good opportunity for a u-bolt flip), bushings, and nitrocharger shocks (might as well get the full OME rear kit). I got it all from Wheelers, they had it organized nice. Never any issues with vibrations, axle wrap, wheels falling off, etc.
  6. Feb 27, 2010 at 9:09 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    yes, they rock!! i just installed them after installing my spindles...and i just moved a ton of stuff...they ride sooo nice! i had the TSB leafs before and these are so much better, loaded and unloaded.
    but, as others have said, you will need the nitrocharger shocks ($175), longer ubolts ($30), and bushings (?).
    search around and you'll find all kinds of info.
  7. Feb 27, 2010 at 9:16 PM
    HDFD10
    awesome thanks guys! Think i will be getting these to help haul more crap around
  8. Feb 27, 2010 at 9:20 PM
    luni
    Burt's Mustache
    Ft Bragg, NC
    TRD OR
    OME 05-Current Tacoma Leaf Spring Set CS047 375.00 375.00 Wheeler's Bushing Kit for CS047 Spring Set ES CS047 BUSH KIT 15.69 15.69 WHE U8504X U Bolt Set 29.95 29.95 OME N182 Shock Set 168.50 168.50 All prices are in US Dollars TOTAL 589.14
    from Wheelers Offroad. Exact same set-up I ran on my old truck. It also lists a carrier bearing drop for $11. Whatever.
  9. Feb 27, 2010 at 9:21 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Hey, I can relate. I camp a lot with my dogs. Have a shell and a home built wood platform for the dogs in back. With a weekend of gear the stock TRD was not cutting it. BTW- I has the 3-leaf on back and not the TSB.
    Anyway, I put on an OME setup. I favored the OME/Dakar leaf pack over the Deaver because the 7 leaf was a nice compromise, although the 10 leaf Deaver is rock solid if you want the ultimate. Anyway, I put on some OME N182 NitroCharger Shocks and longer u-bolts and brake lines and was all set.
    Now my truck doesn't sag at all and the ride is still superb.
    OME ROCKS !!!
    FJ to Taco, Bed Bug and COMAtized99 like this.
  10. Feb 27, 2010 at 9:21 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    remember too that they give ~2.75" lift as well. im running a 4" lift spindle and bils at 0.85" and im slightly higher in the front..
  11. Feb 27, 2010 at 9:22 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    I am running the Dakar rear leaf setup and the front coils as well. The rear leafs are a seven pack but I only using 6 of them cause of the heighth difference from the front. These are great springs and well worth the money.
    But you will need more than just the springs. You will need longer u bolts, possibly a carrier bearing drop spacer.
    Hope this helps ya a little.
  12. Mar 20, 2010 at 5:51 AM
    sbram500
    sbram500 Active Member
    NC
    11 dbl cab 4x4 trd off road
    3" lift, Rock sliders, Fog Light Anytime Mod, Vent guards, Full-Tilt Extang Bed Cover, More to come
    I know this is an older thread, I was just wondering. I have the 2.5 lift blocks in the rear on my 07 Dbl Cab and have the same crappy stock springs. I just ordered the OME springs and bushings. I already have the extended shock from my block lift. My question is, will I have to apply any shims or anything for the angle of my diff for correct driveline angle?
    Thanks for any input you may be able to offer!
  13. Mar 20, 2010 at 6:03 AM
    Silver_Taco
    Silver_Taco Senior Member
    Frederick, MD
    Diff drop - they have it at toytec for cheap I think. That should be all you need. Hope it helps.
  14. Mar 20, 2010 at 4:31 PM
    Peted
    Peted Member
    10 Tacoma TRD Off Road
    I installed the OME kit with Dakar rear springs today.
    The truck is completely transformed!
    I'm using 6 leafs and have no additional lift.
    The stock suspension is a complete joke - I have a 2010 TRD Off Road DC. I seriously doubt that the TSB thing would have been satisfactory to me.
    I'm really glad that I made the decision not to cut corners with fixing my suspension and to do it instead on my own $.
    Tookthree weeks for the backordered springs to arrive and I couldn't wait to get the junk off my truck.
    The only good thing I can say about the stock suspension is that when you upgrade it, you know instantly that you didn't waste your time and money - the difference is night and day.
    Cheers,
    Peter
  15. Mar 25, 2010 at 5:50 PM
    sbram500
    NC
    I can't wait to get my springs! Should be about another week.
    I'll let you know how it turns out.
  16. Mar 25, 2010 at 8:30 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    The Dakars are perfect for hauling and everything else. Get them. Now.
    FJ to Taco likes this.
  17. Mar 25, 2010 at 8:48 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    I'm still deciding on what lift I wanna put on my 2010. I had the 5100s and an aal on my 2006. But I think I wanna go a step up this time around. I was going to get the OME lift kit this time around. Now I haven't really pushed the issue with the dealer about the tsb yet but is it worth it to go through the hassel of getting them to do the tsb and doing another aal or would it be much mire benefical to just save some extra coin and just do the OME springs right away. I'm guessing it would be so much better that way. And now I go with the OME 3" front lift will it sit higher then the rear With the OME springs? Don't they only give like 2.75"?
    Superduner likes this.
  18. Mar 25, 2010 at 10:34 PM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    My set up has 7 leaf Old Man E and it sags like a mofo!!! Took my Tacoma camping for the first time after i bought my lift!! Sag was sad !!! I spent 2k!!! so he could tall me sorry but if you don't want the sag you need to get :mad: $$$ AIRBAGS $$$$:mad: So what you have is great just get Air Bags cost about $350.
  19. Mar 26, 2010 at 8:41 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    ^ you make no sense. Are you just saying that because you have airbags for sale here
    http://www.tacomaworld.com/forum/buy-sell-trade-other/83025-nib-2005-sequoia-air-bags-air-lift.html
  20. Mar 26, 2010 at 8:51 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    ^^^ and since when do the dakars set you back $2000 ?
    OZ
    EB Group likes this.
