Old Model Marlin 80
Discussion in 'Guns & Hunting' started by beastlytaco, Dec 21, 2008.
  1. Dec 21, 2008 at 12:27 PM
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    i recently inhereited my grandfathers old J.C higins Model 80 rifle. i did some research and found that Marlin was the manufacture for the firearm. my question is: does anybody know anything about this 22.?
  2. Dec 21, 2008 at 12:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What do you want to know?
  3. Dec 21, 2008 at 12:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. Dec 21, 2008 at 12:30 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    how does it shoot, are extra magazines available. it doesnt have its magazine. i would like to get some parts for it. its pretty old. probly from the early 50s. and the outside is a bit rusted.not deep rust just surface rust. and the barel could use a good cleaning
  5. Dec 21, 2008 at 12:31 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    oh yeah btw its a 22. rifle. whoops forgot to mention.
  6. Dec 21, 2008 at 12:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Dec 21, 2008 at 12:34 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    its cool.
  8. Dec 21, 2008 at 12:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Does it look like this?
  9. Dec 21, 2008 at 12:35 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    YES!! thats it
  10. Dec 21, 2008 at 12:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://www.gun-parts.com/marlin/
    MARLIN .22 Bolt Action
    10-15-20-101-780-781-80-81-782-783
    State Which Model Parts Wanted
    Any Inside Magazine Assembly.....$35
    Any Magnum Inside Assembly......$40
    Any Model Standard 22 Clip..........$25 <------This is what you want.
    22 Magnum 15 Shot Clip....Net......$35
    Cocking Knob.................................$20
    Extractor Flat Type........................$20
    Extractor Band Type......................$20
    Ejector Wire Type..........................$10
    Flat Firing Pin.................................$25
    Round Firing Pin.............................$20
    Rear Firing Pin...............................$10
    Striker.............................................$20
    Striker Knob New Model...............$20
    Dovetail front Sight.........................$ 8
    Dovetail Rear Sight........................$10
    Rear Sight Elevator........................$ 2
    Safety.............................................Out
    Butt Plate Requires fitting............$25
    Trigger Guard...............................Out
  11. Dec 21, 2008 at 12:46 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    cool, thank you chris. i just didnt really know anything about this gun except that i had it and it was a .22
  12. Dec 22, 2008 at 2:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Ian................be sure to clean the gun really well.............even take it all apart to do so. you want to remove any and all rust from every area you can bro. then.......you may need to spend a few bucks and get a decent gun bluing kit(bass pro and cabelas has them...walmart has a cheap one thats decent too) and reblue the barrel and receiver. just a heads up...............and any springs and moving parts that look like they may be worn pretty bad.......find new stuff for it...kinda rebuild it so to speak. it would not be good if you went and shot it and something malfunctioned on the gun....you could get hurt. just a heads up man.
    oh yeah...............rem-oil is your friend for the most part.:)
  13. Dec 22, 2008 at 3:57 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    thanks, will. I do plan on rebuilding it so to speak. but i got a good buddy of mine who is going to take a look at it and make sure it is still functional. but yeah ill make a note to tell him about the rebluing kit. so how exactly would i remove the light oxidation from the outside of the barrel? by using this rebluing kit?
  14. Dec 22, 2008 at 4:07 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    My grandads old guns were in a damp basement, and showed some rust. I used steelwool, like the "OOO" very fine wool to get at the rust. The Blueing kits are a "Cold Blue" and aren't as good as a hot blue, that involves some pretty nasty chemicals from what I have heard. I did the cold blue from wally world years back. They turned out pretty good, but are a bit lite in some areas. Either I didn't prep the metal enough ot my lack of experience, either way the rust was gone and I make sure I keep oil on them yearly, I don't shoot my grandads guns often. Keep em' dry, use some oil, and think of the guy who gave em' to ya' often.
  15. Dec 22, 2008 at 4:11 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    so did u just scrub the outsude barrel to get the rust off or what. the barrel and underside of the barrel show little to no rust. its mainly the top. Bolt and action a re still in good shape though
  16. Dec 22, 2008 at 4:36 PM
    Monkeysuncle
    Kevin
    Florida
    I just followed the directions on the box, if the gun is a sentimental piece and not a million dollar collector gun then just use the fine steel wool to remove the surface rust and then re-blue it according to box instructions. And yes scrub the gun with steel wool, I think the re blue kit has more than one component. The cleaning, the degreasing and the final blue. It was 15 years ago and the guns are fine. Just get the rust taken car of before you try and refinish the bare metal. Do a Google search on refinishing a firearm/rifle. If the rifle is something you may want to sell then look towards the pros, if you want your children to have it one day, possibly do it yourself. Adds to the history of the gun and makes it a part of you, your grandfather and those you pass it along to.
  17. Dec 22, 2008 at 4:53 PM
    beastlytaco
    Ian
    08 Access Cab SR5
  18. Dec 22, 2008 at 6:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sweet man. i have a 3 shot bolt action .410 that my grand dad gave to me. it was rusty as hell........and i took it apart..........the barrel is pitted underneath, and thats why i say take it apart......cause it may be rusting from underneath too and you just cant see it right away.
  19. Dec 22, 2008 at 7:17 PM
    beastlytaco
    Ian
    08 Access Cab SR5
    but, from the looks, do you think its salvageable? the firing pin works, the springs were well oiled and everything looks good structure wise. oh yeah i fieldstriped it. and the bottom is not even rusted at all. the stock of the rifle kept the underside in good condition. the bolt assembly needs to be oiled.
  20. Dec 22, 2008 at 7:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely............i think you are good to go. but it does need to be cleaned thru the barrel, then taken apart and blue the whole barrel,t hat way, no rust for it man!!
