Old Pickup rims on My 98 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by skipperducker, Apr 26, 2013.
  1. Apr 26, 2013 at 3:06 PM
    skipperducker
    skipperducker [OP] Active Member
    Nova Scotia
    2007 TRD Yamaha Edition
    aluminum rack, 2" leveling kit, soon to be lights and tires
    I have acquired a set of the old steel rims from a '91 pickup. I've got a set of BFG A/T tires the same size as stock to mount on them. The fellow I bought the rims from said that the wheel nuts on my stock rims wouldn't fit the older rims. He has worked on Toyota pickups for over 20 years, so I believe him, but he is on vacation right now.
    What wheel nuts do I need to use with the old rims?
  2. Apr 28, 2013 at 11:14 AM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    are the rims hub or lug centric?
    I see no reason to switch over to a different lug unless it's a different size hole size.
    Throw them on there and check for clearance and see what interference there might be
  3. May 9, 2013 at 6:35 PM
    skipperducker
    Nova Scotia
    Will try when I get my new bfg a/t mounted on them, thanks!
    And they are the hub..
