old school and confused
Discussion in 'New Members' started by beachrunner4x4, Jun 26, 2015.
  1. Jun 26, 2015 at 6:19 AM
    beachrunner4x4
    beachrunner4x4 [OP] Member
    Virginia
    2015 Tacoma TRD Sport 4x4
    front hitch
    This is not only my first Tacoma, but my first post 96 4x4. I built my Jeeps so they would move if only one wheel, front or rear, had traction. Even though I have read a lot of explanations on the Tacoma 4x4 I'm still not sure if all 4 wheels pull. My 2015 has the 4 hi and 4 lo and also the VSC. No other buttons or switches exist. If three wheels are on ice will the one on pavement get traction in 4 wheel drive ? Or does it work like most 4x4's with one front wheel and one rear wheel with the least traction doing all the work ?? thanks
  2. Jun 26, 2015 at 6:25 AM
    Large
    Large Red
    Welcome. I would firstly consult the manual with whateve options your truck came with. I see it says you have a TRD Sport. I'm not sure what the ASC is, maybe you mean VSC?
    beachrunner4x4[OP] likes this.
  3. Jun 26, 2015 at 6:28 AM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    Welcome from another old jeeper . basic answer is yes if you're equipped with ASC it will apply some braking to the slipping wheels channeling power to the wheel with traction. It is not as good as a pair of lockers but will usually keep you moving.
  4. Jun 26, 2015 at 6:28 AM
    beachrunner4x4
    Virginia
    front hitch
    VSC is right. Sorry for the error. I have looked at the manual and it helps some, I just wanted to know if I was understanding it properly. Thanks
  5. Jun 26, 2015 at 6:38 AM
    beachrunner4x4
    Virginia
    front hitch
    Thanks for the help. Relating it back to my old jeep explains a lot. I understand the braking and it sounds like a great system but the manual also went into locked axel buttons etc. My jeeps had cable actuated OX front and limited slip rear with a select trac transfer case. In 4x4 low it would move mountains. Don't get me wrong, I love my Tacoma, just want to know her better.
  6. Jun 26, 2015 at 7:03 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Does a 96 have those features?
  7. Jun 26, 2015 at 7:07 AM
    koditten
    Kirk
    Central Michigan
    I know, just wanted to sure.
  8. Jun 26, 2015 at 11:12 AM
    beachrunner4x4
    Virginia
    front hitch
    Thanks to all for the info.
  9. Jun 27, 2015 at 9:47 PM
    Over da Hill
    Over da Hill "Roads...where we're going we don't need roads"
    Johnny
    SoCal
    15 Black Taco 4WD DC SB SC
    Supercharger, Icon stage 3 suspension, Pelfreybilt Armor, All-Pro Sliders & Leaf Pack, 17 inch Black Rhino Sidewinder wheels, 33 inch Toyo tires, Rigid Lighting, SPod,
