old school shaving
Discussion in 'Off-Topic Discussion' started by nomad, Nov 5, 2010.
  1. Nov 5, 2010 at 3:54 PM
    nomad
    nomad [OP] Well-Known Member
    What do you guys use to shave? I was just curious if anyone around here has gone old school when it comes to getting rid of those facial whiskers.
    For the last year or so I've been using a traditional safety razor. I was using a Mach3, but I use to get a lot of ingrown hairs on my neck. After having switched, they've all but disappeared. Plus, there's just something inherently cool about breaking out the badger brush, a bowl of shaving soap and then whipping it into a good lather. :cool:
    So is anyone here really old school/ hardcore and use a straight razor?
    Here's what I use to get the job done...
    Merkur 34C Heavy Duty Safety Razor
    Feather Double Edge Razor Blades
    Edwin Jagger Silver Tip Badger Shaving Brush
    Tabac Original Shaving Soap
  2. Nov 5, 2010 at 4:07 PM
    ToucanV13
    ToucanV13 You think I was rollin out here naked?
    San Diego and Colorado
    Infideled out TRD Sport 4X4
    285/70 Hankook AT-M, Window vents, TRD CAI, TRD Cat-back exhaust with WickedFlow can, AFE Throttle Body Spacer, Billy 5100 @ 2.5 and 1" block rear, RBP nerf bars, Halo HIDs, 20% tint up front
    Got that razor and brush, but I use The Art of Shaving unscented lather. As a pre-oil the wifey made me a base of avocado oil with Grapefruit, lemongrass, some sandalwood, and orange peel essential oils. Really wakes you up and costs a lot less
  3. Nov 5, 2010 at 7:05 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I use an electric razor. Unless its a formal thing then I use just a razor.
  4. Nov 5, 2010 at 7:16 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    mach 5.
    Is this any better? If so why?
  5. Nov 5, 2010 at 7:24 PM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    My Christmas to me this year is a safety razor, F*** paying $15.00 for 3 damn blade on a Mach 5. I used to use a straight razor, but it screwed up my face and shaving on a boat is precarious anyways...
    Edit: I like some of the ones on taht site, cheaper too...
  6. Nov 5, 2010 at 7:43 PM
    ToucanV13
    Waaaaaayyy better than that pos mach5. All it does is irritate your face more because there's more blades to pull hair out. Plus they go dull with a quickness. You get a way closer shave with the safety razors ;)
    EDIT: And a 10 pack of blades is about 3-4 bucks at a drug store. They last for a good month I've found and when they get dull you flip em
  7. Nov 5, 2010 at 8:04 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Hmm. I might have to try this out. Any one use that "Razor Pit" Sharping tool?
  8. Nov 5, 2010 at 8:09 PM
    nomad
    I'm not sure why. All I can tell you is that it gives a closer, smoother, less irritating shave. One blade is better than 3 or 5. I can also tell you it's sharp as hell. With a new blade and the wrong move, you'll bleed. You learn what not to do fairly quickly though.
  9. Nov 5, 2010 at 8:10 PM
    ink junky
    ink junky I phucking hate people >:(
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    Could I possibly use that to shave my head?
  10. Nov 5, 2010 at 8:15 PM
    nomad
    I don't see why you couldn't. But, with a safety razor, you have to pay a little more attention to the angle you hold it at while shaving. It that regard, it's a little less forgiving than the Mach3's/ Sensors/ etc. That may make it a bit tricky the first few times you do it... until you get the feel of it.
    Edit: I forgot to mention... your choice of blades makes a big difference too. I've tried 3 different brands and the best I've found are the Feather blades (link in first post).
  11. Nov 5, 2010 at 8:24 PM
    evil_umbrellacorp
    evil_umbrellacorp Noob
    Victoria BC
    Taco SR5 4banger
    Hula girl on dash, that's it.
    Those expensive Gillette type disposable razors are giving you razor bumps and irritation because they actually shave TOO close. With a multiple bladed razor, and those fancy rubber strips, they pull the hair up from the follicle and then cut it. The result is after it's cut, the end of the hair is recessed. That's why your face feels so damn smooth. Problem is that sometimes the end of the hair grows in under the skin instead of out of it's original hole. Now you shave again over the resulting bump and you're a bloody mess. The safety razor having only one blade and no fancy rubber strip doesn't pull the hair up out of the follicle. It just cuts it off flush with your skin so there's no way it becomes an ingrown hair. There is technique for getting the best result from a safety razor. The other thing that's great about them is they don't plug up when you have a couple days growth. With my Merkur I could shave my whole face without rinsing the razor and it just keeps working. I use an olive oil soap from the health food store, it's like $1.50 a bar and lasts forever. If I have time I use my badger brush.
  12. Nov 5, 2010 at 8:36 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Anyone ever use straight razors?
  13. Nov 5, 2010 at 8:38 PM
    nomad
    I'm chicken.. bock, bock, bock.
  14. Nov 5, 2010 at 8:58 PM
    ToucanV13
    I want to try it out, Chick at AOS told me to youtube it. Said the instructional vids were actually really good and dead on
  15. Nov 5, 2010 at 9:03 PM
    ink junky
    TACO LOVER
    TEXAS
    hahahahaha
  16. Nov 5, 2010 at 9:15 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Yeah I'm kinda afraid to try it too....lol
  17. Nov 6, 2010 at 1:06 PM
    Jones
    Jones Well-Known Member
    Texas DFW
    06 SSM Prerunner TRD-OFFROAD
    Front: 5100@1.75 with SR5 coils; Rear: 5100 and 1.5 Toytec aal; Tires: Hankook 265/75R16 RF08 ATM; Wheels: powdercoated off-road wheels with FJ TRD center caps
    Good to see I am not the only one out there not using the plastic disposable stuff to shave.
    I have been using this safety razor for about 5 years and love it.
    Merkur Futur
    http://www.westcoastshaving.com/Merkur-Futur-Safety-Razor-Matte-Chrome_p_51.html
    Col. Conk shave soap , Amber glycerine or Bay Rum
    http://www.colconkproducts.com/index.php?main_page=index&cPath=3&zenid=jhgptb15bkpbsijlllkld24or3
  18. Nov 6, 2010 at 1:11 PM
    nomad
    Nice razor. Being adjustable, does it hold it's position solidly once adjusted? Also, does it flush out easily? It looks like the bottom of the head is closed in.
  19. Nov 6, 2010 at 1:23 PM
    Jones
    Texas DFW
    It is pretty stiff to turn, I wouldn't attempt to turn it with a blade in it. I wasn't sure how close I wanted the razor to be when starting to use it, so I went with the adjustable one. It flushes out fairly well, a little soap build up over time but nothing major.
  20. Nov 6, 2010 at 2:06 PM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
    I just came across this thread and I'm interested in trying this out. I use a Mach 3 right now. What do people prefer, Adjustable or Non Adjustable Safety Razor? Is it easy to get a nice close shave? How long does it take to shave? I got a razor from my Grandfather that was made in 1932 and used in WW2 that I'd like to use, I imagine it will still use a standard blade?
