Old Tacoma Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by brandon1298, Dec 10, 2013.
  1. Dec 10, 2013 at 11:51 AM
    brandon1298
    brandon1298 [OP] New Member
    Hello everyone , my name is Brandon and I own a 1989 Toyota Tacoma . Now recently I just got a new problem going on ( well more like a sound ) before the big problem happens... And it concerns me because well, it's an engine sound, which is usually not good. Now it seems a bit connected to the breaks cus every once and awhile when I break , the sounds happen. Now the sound is like the engine revving for less than a second and stopping and then revving for a second again (on and off revving...) and it keeps repeating, anyone else have this issue before??? Any info helps, thanks!
  2. Dec 10, 2013 at 12:25 PM
    Sin
    Sin Well-Known Member
    Superior, Wisconsin
    1996 Tacoma SR5 4x4 excab 3.4
    Is the engine revving or does it just sound like its revving?
    You can take a look at these posts maybe their related..good luck!
    http://www.tacomaworld.com/forum/search.php?searchid=10573886
  3. Dec 10, 2013 at 12:27 PM
    brandon1298
    It's sounds like the engine revs for a half second like as if you are putting your foot on the pedal and taking it off immediately(pretty much
    That process but on repeat)
  4. Dec 10, 2013 at 12:57 PM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Check your vacuum lines for damage and proper routing (including brake booster lines).
  5. Dec 10, 2013 at 12:58 PM
    brandon1298
    Ok thanks!
