OME 2 inch lift ride quality
Discussion in 'Suspension' started by roth_nj, Feb 18, 2017.
  1. Feb 18, 2017 at 3:12 PM
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    I think I've narrowed in on the OME 2 inch lift kit. I'm only looking for a inch or two of lift. Want something, but want to keep it one the lower end to reduce complications. And having messed around with adjustable coil overs in the past (but to lower cars), I like the set height.
    How's the ride quality with this kit? I have the off-road and like the ride. If anything, I would like to stay in the same ballpark if not plusher.
    I plan on getting rock sliders as soon as mobtown has their group buy soon. If I do a bumper, it will be a slimline one so won't have to compensate for much weight
    trabo likes this.
  2. Feb 18, 2017 at 3:18 PM
    Hautian
    Hautian Well-Known Member
    Upper Peninsula, Michigan
    2016 Silver TRD OR - sold / 2022 4Runner
    I think it rides better but I had my topper on prior to my Dakar springs so the rear may ride a little stiffer than stock without anything. I have 885 springs but I don't think there would be much difference if you go with the 887 because they are the same spring rate.
    All in all I think it rides smoother.
  3. Feb 22, 2017 at 10:45 AM
    roth_nj
    bump......
  4. Feb 22, 2017 at 11:01 AM
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    I'm interested in the same setup. On the ARB website, it has a kit for stock weight. For that one, they take out a leaf from the Dakars. That is the one I think I would get, but like you OP, I like the ride of the stock off-road and wouldn't want it a whole lot stiffer.
  5. Feb 22, 2017 at 5:10 PM
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    does that kit need anything else to help keep it aligned ?
    i would like the front stiffer
  6. Feb 22, 2017 at 5:22 PM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I have that kit on 886 (Heavy kit) springs since I have an ARB bumper with a winch, and I carry a lot of weight on race weekends. When the bed is empty the rear is stiffer than stock but its exaggerated by my tire choice (unknowingly purchased an E-rated tire). I love this kit and would definitely recommend it but I'd call ARB if you have questions over the correct springs. They were very helpful when I was deciding what route to go. I could have gone softer in the rear but I'd rather deal with the stiffer ride when empty than to be bottoming out when loaded down and off-road. I also plan to add a high clearance rear bumper and some skid plates which will help the ride quality when the bed is empty.
    Everything you need is included in the kit including the drivers side trim packer to account for the Taco lean. I installed the diff drop spacer but some on here choose not to. You don't need new upper control arms either. I was able to get it aligned without issue and it drives great. I have no complaints and it gave me more lift than I was expecting so that was a nice plus.
    Hamer95USA and jnw32 like this.
  7. Feb 22, 2017 at 10:38 PM
    16TRDoff_road
    16TRDoff_road Active Member
    Brett
    Cornwall, NY
    2016 Tacoma TRD off road quicksand
    Full OME Kit (888 coils, Dakars), 285/70r17, Pro Comp Rockwell wheels
    I completely recommend the OME kit. I have a full OME kit, 888 coils and dakars in the rear with Camburg UCA's. It rides better than stock, in my opinion it's a night and day difference.
    Hamer95USA, TacoTrooper and jnw32 like this.
  8. Feb 23, 2017 at 8:10 AM
    jnw32
    Dallas, TX
    Do you think it would have been ok without the new UCAs? Thanks.
  9. Feb 23, 2017 at 8:35 AM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    They are fine without aftermarket UCAs. Alignment will be trial and error - shoot for positive caster at the same time trying to get camber as close to 0.
    Also, when you lift with OME (and other lifts), your stance gets narrower. A friend of mine had the same lift but with 285s with stock wheels. The tires rubbed the UCAs, fixed with SCS wheels
    trdeez and jnw32[QUOTED] like this.
  10. Feb 23, 2017 at 8:38 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    From a friend who had the kit, the fronts ride great but the rears are stiff. I'm thinking about doing just OME fronts paired with fox 2.0s in the rear.
    The valving is pretty soft, if you want that cadillac ride quality, but a ton of body roll, squat and dive.
    I'm also considering the bilstein 6112s which cost more, but are a lot beefier. The main difference though is that the bilsteins are digressive (like icons) versus progressive.
    2016MGMTACO and jnw32 like this.
  11. Feb 23, 2017 at 10:47 AM
    lamia2super
    Frank
    Miami Beach, FL
    where is the best online site to purchase the kit ? does it include a diff drop spacer? also does the kit resolve the small lean the truck has
  12. Feb 23, 2017 at 10:58 AM
    roth_nj
    best i dont know....
    prices seem to be pretty similar all around, but free shipping here
    http://www.headstrongoffroad.com/store/c130/OME_Kits.html
  13. Feb 23, 2017 at 10:59 AM
    roth_nj
    diff drop spacer - no
    taco lean spacer - yes
    tacoshin likes this.
  14. Feb 23, 2017 at 10:59 AM
    roth_nj
    does he have the 3aal in the back or the dakar packs?
  15. Feb 23, 2017 at 11:04 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I believe the dakar pack initially. But this was for a 1st gen. Now he has a custom chevy leaf suspension paired with fox shocks.
    Tlharvey likes this.
  16. Feb 23, 2017 at 11:16 AM
    WZ KTM
    WZ KTM Member
    Colorado
    17 TRD OR
    OME/Dakar SPC LR 285/75/16
    I'm running the full OME/Dakar with 888 front coils with 1/4" spacer on driver side and there soft ride shocks. Front side to side are perfectly level. Front to rear has 1" rake with an ARE topper. I also went with SPC uppers just for piece of mind knowing the alignment is dead nuts on. Compared to stock the ride is SO much better. Check pricing between Headstrong Offroad and Low range offroad.
    Both excellent company's to deal with.
    WZ.
    Hamer95USA likes this.
  17. Feb 23, 2017 at 11:19 AM
    16TRDoff_road
    Brett
    Cornwall, NY
    I went with headstrong, free shipping. There's no diff drop spacer but they include the spacer for lean. It also comes with a carrier bearing drop spacer. Diff drop is not needed. Basically repeating what roth_nj said haha.
  18. Feb 23, 2017 at 3:26 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    What do you mean by so much better? More plush? Better handling? From what I understand it will ride softer, but will have more body roll, squat and dive during on-road driving.
  19. Feb 23, 2017 at 3:29 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  20. Feb 23, 2017 at 4:05 PM
    WZ KTM
    WZ KTM Member
    Colorado
    17 TRD OR
    I wouldn't say more plush just a firmer ride. Cornering is solid. Not a sports car by any means it just has a nice planted ride to it. Spacers and 285 E's contribute to that also I'm sure. I live in the mountains and drive the twisties every day. No complaints
    Shortbus47XYY likes this.
