OME 2 inch lift ride quality
Discussion in 'Suspension' started by roth_nj, Feb 18, 2017.
  1. Feb 23, 2017 at 4:20 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    ChadsPride and ramonortiz55 like this.
  2. Feb 23, 2017 at 4:26 PM
    WZ KTM
    WZ KTM Member
    Colorado
    17 TRD OR
    OME/Dakar SPC LR 285/75/16
    No. That would be my TJ on 35s :turtleride:
  3. Feb 25, 2017 at 5:04 PM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
  4. Feb 25, 2017 at 6:21 PM
    99superduty
    99superduty Well-Known Member
    2016 DCSB OR 4x4 OME LIFT W/886 and DAKARS 265/75/16 Duratracs C4 lo pro bumper
    I've got the OME Heavy (886) kit w/dakars on mine and while its a little stiffer than stock, its by no means harsh.
  5. Feb 25, 2017 at 11:55 PM
    K2a100
    K2a100 Active Member
    Kevin
    2016 Red Tacoma Trd Off road
    I just installed ome 888's tonight and this it's a little more plush than my stock ride. It looks more than 2" but I'll be measuring tomorrow. Love it so far though
  6. Mar 7, 2017 at 6:27 AM
    jnw32
    jnw32 Well-Known Member
    Dallas, TX
    2016 White Tacoma TRD Off-Road DCSB
    265/75/16 KO2s, SR5 Grille, TRD Pro skid plate, Husky X-Act Contour floor mats, Carhartt front seat covers, de-stickered, partially de-badged, Bilstein 5100s with one inch rear block
    Do you still like it? Do you have any extra weight on your truck? Thanks.
  7. Mar 7, 2017 at 8:10 AM
    K2a100
    Kevin
    I do still like it! Rides nice! I don't have extra weight yet. I do intend to have a hidden mount winch in the future but for now it's still great
    jnw32[QUOTED] likes this.
  8. Mar 7, 2017 at 8:16 AM
    tacoshin
    tacoshin Well-Known Member
    Brian
    the name of my truck, WA
    2008 Lexus IS250 AWD/2014 Tacoma SR5 4x4 short bed
    Smittybilt step bars, Toyota skid plate, All Pro bed rack w/ tonno pro retrofitted thanks to pushingcasket for helping, trd exhaust 14019 miles
    before you install the lift I would say to check on the tsb for the needle bearing on your truck. cause the dealer will try everything they can to not get that tsb for it with the lift. if you do get the lift before the tsb that is if they have one for the 3rd gen, get ECGS bushing and install that it will kill the humming and the womp womp womp sound from your diff. I got the 885 spring with the arb bumper. I have a rake but I like it that way. the rear just 3 leaf aal with overload on, it is a lil stiff but I just have a apex bed rack so its not too bad.
  9. Mar 7, 2017 at 8:55 AM
    roth_nj
    roth_nj [OP] Well-Known Member
    2017 DCLB trd off-road bbp
    i was on the side of just doing the ECGS bushing at the same time as lifting it...
    ive heard it a bunch that toyota just replaced the needle bearing with another needle bearing that then fails again..
  10. Mar 7, 2017 at 9:09 AM
    tacoshin
    Brian
    yeah I heard that the new needle bearing for the tsb is better than the original one from another member on here but I tried to get my tsb but these numb nuts at the dealer said they couldn't replicate the sound and I told him about the play and they said,there is suppose to be play on the axle. so I ended up installing the bushing. but ever since I replace the bushing no more sound and way better. also make sure you get the rubber seal. because you will probably end up ripping it up. because there is a metal clip in the seal that will come apart unless u know how to remove it clean. and that seal is on there tight.
  11. Mar 7, 2017 at 9:16 AM
    natas1321
    natas1321 mischief monkey
    natas
    san antonio
    1990 Honda NC30 stock for now
    I have the full OME kit with 885's and it is a bit stiffer than stock but not bad by any means as I do use it as my daily as well as my weekend toy. I did originally have the 886's and was not happy as it was a bit too high and stiffer than what I wanted, I did also go with some total chaos uca's.
    tacoshin likes this.
  12. Mar 7, 2017 at 9:21 AM
    tacoshin
    Brian
    ditto @natas1321 I had the 886 and it was up 3 and half inch and my cv was all cocked eyed, but if you don't have anything heavy you will be fine with 885. plus as I said in the OME section of TW you can replace the 885 for any other spring before 90 days of use all you have to do is call ARB in auburn WA and they can hook it up. that's what I did but I live here in WA so I just drove up and got the spring and went to a shop they are associated with and had them re install it.
  13. Mar 7, 2017 at 9:24 AM
    natas1321
    natas
    san antonio
    nice, I had the 886's with an allpro bumper on the front but it was still more of a lift than I was looking to get I thought it would settle a bit more than it did and ended up going with the 885's after talking to marie at headstrong and could not be happier.
  14. Mar 7, 2017 at 9:28 AM
    tacoshin
    Brian
    yup I bought my set from HS, marie does know her stuf and she hooked it up at the time. I know that even though we have same trucks etc. there is always flaws or some doesn't work right, which is weird, IE: one with the same lift will have 3 inch lift or other will have 2 in. etc. so yeah I got the 9000 shocks with 885 and nitro in the rear with icon 3 leaf aal with overload. love it too. @natas1321 I did want the all pro bumper but couldn't afford that extra shipping so I went with ARB bumper. maybe one day I will change to pelfrey or allpro
    Hamer95USA likes this.
  15. Mar 7, 2017 at 9:31 AM
    #35
    natas1321
    natas
    san antonio
    Nothing wrong with the ARB they do make some nice bumpers.
    Hamer95USA and tacoshin like this.
  16. Mar 7, 2017 at 9:34 AM
    #36
    Flytmech
    Flytmech Well-Known Member
    Jase
    Geneva Alabama
    2016 Tacoma TRD OFFROAD 4x4
    All Pro Offroad bed rack Defender Basket OME/Dakars Total Chaos ucas C4fabrications LoPro Smittybilt 9.5 comp Uniden 520xl (tuned) CVT Mt. Shasta Black Oak 50 curve led
    Front 90021 softer rides, rear 60091 sport w/Full Dakar leaf pack.Total Chaos Ucas. 2 inches of lift all around/maybe a little more. I have a C4 Fabrication Lopro bumper up front with a smittybilt 9.5 comp winch(130 lbs total). I did not remove the last leaf of the Dakar Without the bed loaded (rtt/camp gear) it's a bit stiff. Ome says to remove last leaf if you run less than 300 lbs normally. With the bed fully loaded (300lbs+) the ride is perfect, especially over rough terrain at 40-45mph is where it seems to really shine. 20170226_162715.jpg
    Buy from Headstrong Offroad.
  17. Mar 7, 2017 at 10:01 PM
    #37
    s1t808
    s1t808 Sitting in the timeout corner
    HI > OCONUS
    2015 Taco
    Lift? Yea I got one of those
    I got the full OME setup last week to include SPC UCAs for peace of mind. Just had to add top plate spacer to even out the rake. Went with a local shop and they suggested 883s which works perfect for my AC 2wd. So far truck just eats up all the bumps and dips in our horrible roads out here. Time will tell if I decide to go with a higher spring rate.
  18. Mar 8, 2017 at 3:21 AM
    #38
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Shoulda gone with 884s and ditched the top plate spacer. The 883s, 884s, and 885s are all the same coil, just different lengths. with 883 being shorter and 885 being longer.
  19. Mar 13, 2017 at 10:30 AM
    #39
    Rus TRD
    Rus TRD Well-Known Member
    Don
    Pa.
    2015 DC TRD Sport
    Bilstein 5100 with 884 Springs. Full audio system. Stealth 6 Wheels. Cali led light.
    I bought my 5100's and 884 coils from Headstrong off-road. They don't recommend for a double cab. It lifted my truck 2 inches. Did not do anything to the rear yet. My 2015 TRD sport handles and rides really good. No Vibrations and I have a lot of back roads.
  20. Mar 13, 2017 at 11:45 AM
    #40
    lamia2super
    lamia2super Well-Known Member
    Frank
    Miami Beach, FL
    2016 Tacoma TRD Off-Road, (sold) 07 Tacoma xRunner
    I've been looking at the Dobinson Suspension kits with there parabolic leaf springs for my truck
