OME 2" lift with 275/70 70s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Doghouse61, Oct 18, 2020.
  1. Oct 18, 2020 at 1:18 PM
    Doghouse61
    Doghouse61 [OP] Well-Known Member
    Paul
    Calgary
    If I go with the OME 2" lift on my 2020 Taco, will I run into tire interference problems if I run 275/70 70 KO2s?
    4×4×4 likes this.
  2. Oct 18, 2020 at 2:39 PM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    70” wheels won’t fit, no matter how much you trim.
    71tattooguy likes this.
  3. Oct 18, 2020 at 3:03 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  4. Oct 18, 2020 at 3:25 PM
    Doghouse61
    Paul
    Calgary
    Thank you for the reply; but do you think 275/65 17 would work in this situation?
  5. Oct 18, 2020 at 3:26 PM
    Doghouse61
    Paul
    Calgary
    Sorry, I just realized my mistake; would 275/70 17s work?
  6. Oct 18, 2020 at 3:29 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Do lots of research before you buy anything. There's alot more to lifting these trucks than just installing a set of coilovers or spacers. Good luck with your truck and welcome to TW.
  7. Oct 18, 2020 at 3:29 PM
    sbx22
    sbx22 Well-Known Member
    Norcal
    2020 TRD DCSB OR 4x4
    There's a huge 275/70 thread around here. Look for it. I don't have 275s so idk.
  8. Oct 18, 2020 at 3:30 PM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    Lift=/=Tire clearance. It's really hard to say with that combo but you might have to cab mount chop depending on your wheels.
    And welcome to TacoWorld!
  9. Oct 18, 2020 at 3:46 PM
    beergeek
    RI
    I have an OME 2” lift and 275/65/18 tires, which are the same width and diameter as 275/70/17s. They will be fine, depending on the offset of your wheels and alignment settings.
  10. Oct 18, 2020 at 4:58 PM
    Doghouse61
    Paul
    Calgary
    Thank you to everyone; I appreciate your opinions and input. I was thinking of SCS Rays 10s to go with these tires.
  11. Oct 18, 2020 at 5:02 PM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    It's the offset that makes the difference but I think you'll be alright.
