OME 2" Lift
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mgibs83, Dec 28, 2021.
  1. Dec 28, 2021 at 11:58 AM
    Mgibs83
    Mgibs83 [OP] New Member
    Michael
    2021 od green Tacoma
    2” OME, Method 17x 8.5, Falken Wildpeak 265/70
    Im installing a OME 2" lift this weekend on my 2021 Tacoma. Ive heared about a vibration that happens while deceleration with lifted Tacoma's. Will I get this with a 2" OME Lift with the bearing spacer installed? Also do need to change out the upper control arms? Thank you
    Junkhead and tacotoe like this.
  2. Dec 28, 2021 at 11:59 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Hopefully not.
  3. Dec 28, 2021 at 12:00 PM
    SpeySquatch
    2016 TRD OR DCSB
    If you do the ECGS clamshell bushing replacement of the driver side needle bearing you should be good to go. I installed the same exact lift and got the vibe and chased it for months before getting the bushing replacement. It fixed everything and drove fine after
    also, as others have said. Get some aftermarket UCAs such as SPC or JBA
    mac84 and 71tattooguy like this.
  4. Dec 28, 2021 at 12:09 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    UCA’s are a must IMO
    Junkhead, Pinion and SpeySquatch like this.
  5. Dec 28, 2021 at 12:20 PM
    Mgibs83
    Michael
    Thanks for the info. Hopefully I wont have this issue. Do you have a link I can check out for ordering info?
  6. Dec 28, 2021 at 12:23 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    "Google ecgs tacoma bushing."
    71tattooguy and SpeySquatch like this.
  7. Dec 28, 2021 at 12:26 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What are the lift specs?
    Which shocks? Which coils? What shock setting? For example, I'd you went with 5100's and OME coils they should be installed on the bottom setting ONLY.
  8. Dec 28, 2021 at 1:25 PM
    gudujarlson
    Minnesota
    tacotoe likes this.
  9. Dec 28, 2021 at 1:42 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You might be totally fine or you might need ECGS bushings, or/and 3 degree shim in the back.
    I did 2” OME lift and needed the shim only.
  10. Dec 28, 2021 at 1:42 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I didn't have any vibration. As far as upper control arms, I didn't add those but my alignment was a very small amount out of specification on the front passenger side. I bet there's a good chance it could be attainable now after a few years and a little spring sag. I also ran it 30k -40k miles(with lift) before replacing the bearing with a bushing.
    ECGS = East Coast Gear Supply .....FYI
    If you decide to do the bushing later and need the tools, just ask around here on TW....someone help you out with that.
    Junkhead likes this.
  11. Dec 28, 2021 at 1:43 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    From what I understand, if going with 2” lift they are not necessary.
    tacotoe likes this.
  12. Dec 28, 2021 at 1:46 PM
    gudujarlson
    Minnesota
    While not specifically the OME 2" kit from ARB, my kit from headstrong came with OME Dakar leaf packs and a OME carrier bearing drop kit; no rear axle shim. I have not had any vibration issues. I also did not install an ECGS bushing.
    tacotoe and Junkhead[QUOTED] like this.
  13. Dec 28, 2021 at 1:54 PM
    geekhouse23
    71tattooguy and tacotoe like this.
  14. Dec 28, 2021 at 1:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Well it doesn’t matter what 2” suspension lift you get, some tacos run into minor vibration issues. It seems to be hit and miss though. My kit did not come with a shim, I had to go back and have it added.
    I don’t understand why it vibrates on deceleration only, I would have thought it would vibrate the whole time since the driveshaft angle is changed.
    tacotoe likes this.
  15. Dec 28, 2021 at 1:58 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Yes!! But every truck is different. Let’s see how OP works out after lift. Caster Camber etc. Hopefully at least he has a good alignment tech
  16. Dec 28, 2021 at 1:59 PM
    DuffyBank
    DuffyBank Well-Known Member
    OME 886 with 90000 Nitrochargers in the front, Dakar 112R in the rear, stock UCA and needle bearing, no vibration. Front came up 2.25 (hub to fender). Bumper and winch going on in 10 days.
    Mgibs83[OP], tacotoe and Junkhead like this.
  17. Dec 28, 2021 at 2:04 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Speculation on why it would only vibrate on deceleration could be slight axle wrap.
    The kit I installed came with the shim as part of the lift kit.
    This lift kit was installed on my wife's 2nd generation and it's basically the same lift kit except on 3rd generation it's 2" instead of 2.5" because they sit higher half inch factory.
    Junkhead[QUOTED] and 71tattooguy like this.
  18. Dec 28, 2021 at 2:18 PM
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    I went 2” on my 2013 because I wanted less wear, tear and strain from changing the angles. I used 884’s up front and full leaf pack in rear. Zero issues. So much nicer than stock ride. No need for UCA’s.
    Nice choice OP.
    I didn’t use the supplied drop spacer.
  19. Dec 28, 2021 at 3:23 PM
    Mgibs83
    Michael
    Yes that’s the one I’m installing
    tacotoe likes this.
  20. Dec 28, 2021 at 3:27 PM
    geekhouse23
