OME 2885 springs definitely sag over time, lift settled 48%-58% since new
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dal3_gribble, Jun 14, 2019.
  1. Jun 17, 2019 at 3:34 PM
    w:ll:s
    w:ll:s Well-Known Member
    Nashville, TN
    2001 Tacoma v6 4x4 SR5 - Imperial Jade
    brand new truck, why cheap out on the suspension if changing it? Coilovers will let you adjust to your liking.
    whatstcp and Gingerbeard Man like this.
  2. Jun 17, 2019 at 4:51 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Increasing positive scrub > increases wheel length > lowers motion ratio > lowers wheel rate(effective spring rate measured at the wheels).
    Motion ratio=arm length/wheel length
    Wheel rate=spring rate x motion ratio^2
  3. Jun 17, 2019 at 4:57 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  4. Jun 17, 2019 at 5:01 PM
    splitbolt
    NW Arkansas
    I keep telling you, you listen to me more, you live longer.
  5. Jun 17, 2019 at 5:03 PM
    hyper15125
    NJ (609)
    :bowdown:
  6. Jun 17, 2019 at 5:05 PM
    splitbolt
    NW Arkansas
    :D
  7. Jun 17, 2019 at 5:07 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Considering the pro is ~1" higher in the front than the OR and the way yours looks now, I feel confident that you've still got more than a 1.3" lift up front. Try taking the picture with the truck in the same place, the ground level looks different in both pictures.
    Either way, I hope I end up with something similar to your June pic.
  8. Jun 17, 2019 at 7:25 PM
    dal3_gribble
    dal3_gribble [OP] Well-Known Member
    Crew Cab SB TRD Offroad
    Thanks! Well, remember the pics are with .25" strut spacers (~.5" lift) also. It's just under 2" probably.
  9. Jun 17, 2019 at 7:34 PM
    SpeySquatch
    2016 TRD OR DCSB
    The problem is that these 3rd gen trucks need 650-700# springs to not sag. There is a reason the stock coil on those squishy valves Billys are 700#
    DevilTaco4 and whatstcp like this.
  10. Jun 17, 2019 at 8:05 PM
    elduder
    Van WA
    You're right, forgot that.
  11. Jun 19, 2019 at 6:11 AM
    dal3_gribble
    Fixed my problem.
    whatstcp likes this.
  12. Jun 19, 2019 at 7:00 AM
    Gsingh916
    Gsingh916 Well-Known Member
    2019 Toyota Tacoma trd Offroad
    What did you do to fix the problem?
  13. Jun 19, 2019 at 7:12 AM
    dal3_gribble
    4" front spindles and added an add-a-leaf on back to level back out.
  14. Jun 19, 2019 at 7:15 AM
    Roddy13
    Roddy13 Well-Known Member
    What a load of shit. what does OME say?
  15. Jun 19, 2019 at 7:17 AM
    #35
    dal3_gribble
    I'm going to send springs back. We'll see.
  16. Jun 19, 2019 at 7:45 AM
    #36
    Ryan at Eibach
    Ryan at Eibach Well-Known Member Vendor
    Sub'd :)
    whatstcp and iK0NiK like this.
  17. Jun 19, 2019 at 8:23 AM
    #37
    jasontylers
    jasontylers Well-Known Member
    JT
    2016 Tacoma TRD Off Road
    None.
    Doesn’t it affect ride quality and integrity once you lift above 3”?
  18. Jun 19, 2019 at 8:25 AM
    #38
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    Lolz
    Mully likes this.
  19. Jun 19, 2019 at 8:28 AM
    #39
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    He's 2wd.
    Junkhead likes this.
  20. Jun 19, 2019 at 8:53 AM
    #40
    eurowner
    eurowner Duke Sky
    Scoty
    Thanks for doing that. The other thing throwing my eyes off is that the 2019 pic has different rims and tires, filling the wells more.
