OME 3 Inch
Discussion in 'Suspension' started by Artery3, Sep 23, 2013.
  1. Sep 23, 2013 at 6:02 PM
    Artery3
    Artery3 [OP] Member
    Jake
    OC
    08 Prerunner
    So I decided to go with the OME 3 inch suspension lift.
    It will be the 885's with top spacer for the full 3 inches as I have a Double Cab.
    Right now measuring, My rear is about 1.5 to 2 inches higher in the rear. I want my truck relatively level... With that said should I go with the 1.5 aal or the 2.0 aal? I talked to ToyTec and he says that to make it "level" I need 2.0, however by my calculations that still leaves it an inch higher in the rear. Anyone whos done it or has any info id appreciate it! Hope this make sense. Thanks a lot!
  2. Sep 23, 2013 at 6:06 PM
    tomwilson74
    tomwilson74 Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I did the 1 1/2 and wish now I had the 2" in the back. You can check out my pic's. The back sits a little lower than the front.
  3. Sep 23, 2013 at 6:08 PM
    Artery3
    Artery3 [OP] Member
    Jake
    OC
    08 Prerunner
    Thanks for the reply. So you used the spacer on top of the 885s?
  4. Sep 23, 2013 at 6:25 PM
    Dick Proenneke
    Dick Proenneke Well-Known Member
    Edmonton, Alberta
    2013 TRD Sport 4X4
    OME 3" Lift with DAKAR'S, LR UCA'S, ECGS Bushing, Leer Cap, 18" Dick Cepek Torque', Duratracs, custom drive shaft, etc!
    I have the OME 885's with 1/2" top spacer and Dakar's. I have 1/2" of rake. With no top spacer I'm at 1.5" of rake. DCSB 4X4.
  5. Sep 23, 2013 at 6:52 PM
    tomwilson74
    Tom
    West Virginia
    I don't really know, I had it installed at a local garage.
