OME 3" lift: 6 or 10mm top spacer? 5mm trim for taco lean?
Discussion in 'Suspension' started by cdn_bacon, Feb 1, 2010.
  1. Feb 1, 2010 at 7:10 AM
    cdn_bacon
    cdn_bacon [OP] Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    I'm lifting my truck this weekend and got my OME parts in [9000+885's, AAL]. Regarding the top spacer to bring the front up to a full 3", I've heard 6mm and 10mm spacers? Which do you need? Would the 4mm diff really make that much of a difference? (i.e. I have a set of 6mm already :confused:)
    Also, should I install the 5mm trim into the drivers side strut? I've heard you should to correct "taco lean" although I haven't noticed any lean...opinions?
  2. Feb 1, 2010 at 7:18 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the bigger one goes on the drivers side to compensate for the "taco lean" the weight of the driver and the gas tank making the truck uneven
  3. Feb 1, 2010 at 7:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    When you say you haven't noticed any lean....Did you measure that or just eye ball it?? Cause I didn't notice it on mine either- but the measurements showed different. I would install the trim packer (in between the shock and the spring cup-drivers side only).
    6mm should get you mighty close to 3 inches. Mine with no spacer is about 2.2 inches total....and a 6mm spacer would get that closer to 2.8ish.
  4. Feb 1, 2010 at 8:29 AM
    cdn_bacon
    Christopher
    Houston
    I'm no dummy by any means but this one makes no sense to my logical brain...what do you think?
    [email fr me to vendor who sold me the .25" top plate]
    This is going to sound like a stupid question I'm sure, but how does a 0.25" spacer give 0.5" lift?
    [email response from vendor]
    The lift ratio on your Toyota is a 2:1. With independent suspension you do not have a lift ratio like the 1:1 of a straight axel. The spacer pushes the strut down. When you strut pushes the center of the control arm down, the outside of the hub moves down twice the amount that the spacer measures.
  5. Feb 1, 2010 at 10:33 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Forgive me if this sounds stupid, but if you can't look at a lifted truck and tell there is a lean. Then why would you care about 6-8 mm of height difference in the front?
    We are talking about a little over 1/3 of an inch.
    |__| <<<that's about the difference right?
  6. Feb 1, 2010 at 12:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I leveled all of my trucks to within 1/8"......Who cares?
  7. Feb 1, 2010 at 6:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I couldn't see it on my stock setup- but when I measured it there was surely a difference. I would care because it can be- It's suspposed to be level.
    And with the trim packer you are talking about .19 inches....not .33333.
    Plus- People eyeball shit all the time....Doesn't mean it's right.
