OME 3" Lift - Front Clunking Issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigwill837, Jun 28, 2017.
  1. Jun 28, 2017 at 8:38 AM
    bigwill837
    bigwill837 [OP] Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    Several months ago I installed a full OME 3" lift kit with 883 springs, Dakar rear leaf packs, Total Chaos UCAs, and Wab Fab Quick-Disconnect End Links.
    Initially the truck rode and drove fine. Over the past several weeks I have noticed a clunking noise from the front passenger suspension. It's really noticeable at 20-30 mph over uneven/rough roads. You can feel the clunking through the cab of the truck. My repair shop has continually tried to diagnose the clunking, but can't find the source. They inspected and re-torqued everything on the front end.
    Is there a common failure point for lifted trucks on the front end? Maybe the lower ball joints or lower control arms?
    Thanks in advance!
    AlecYourTaco and ChadsPride like this.
  2. Jun 28, 2017 at 8:46 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    This is common on the 2nd gen trucks with OMEs at 3" in the front. The clunk in that case is from the shocks topping out and extending to their max. You can usually test it by going over a speed bump.
    jmaack and ChadsPride like this.
  3. Jun 28, 2017 at 12:18 PM
    ckoontz
    ckoontz Active Member
    Topher
    Seattle
    03 Prerunner converted
    5sp, 4x4 conversion, manual hubs, 4.56
    Subbed. I have the same problem, same identical setup.
  4. Jun 28, 2017 at 12:19 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    It's the shocks, like said above.
    Normal by design, but annoying as all fuck.
    04tacoadobo and jmaack like this.
  5. Jun 28, 2017 at 1:46 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Is it normal and known on first gems as well?
  6. Jun 28, 2017 at 1:51 PM
    T4RFTMFW
    Nothing to do with trucks.
    It's the OME design. Internal metal bumpstops limit over extending. When the shock bottoms out it makes a bang noise.
    Brice, jmaack and FirstTimeFirstGen like this.
  7. Jun 28, 2017 at 3:25 PM
    TRD4WD
    TRD4WD Supreme Leader
    Micah
    Gonzales, LA
    2004 Double Cab TRD
    I have the same setup and get noises that I thought were coming from the front passenger side, come to find out it was coming from the rear passenger side leaf springs.
    FirstTimeFirstGen likes this.
  8. Jun 28, 2017 at 4:07 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    kind of glad I saw this thread. I've had noises since day one of the install. thought maybe it was something moving or hitting the frame.
    so is it "topping out" or "bottoming out" that makes the noise? two different responses on here...
  9. Jun 28, 2017 at 4:53 PM
    TRD4WD
    Micah
    Gonzales, LA
    2004 Double Cab TRD
    My noise is at low speed moving. I can't hear mine at higher speeds so it may not be the same noise.
  10. Jun 28, 2017 at 7:12 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    oh, it's when I'm moving at 10-20 mph down the street and over potholes :)
  11. Jun 28, 2017 at 8:16 PM
    maulcruiser
    maulcruiser Well-Known Member
    Wilmington, NC
    96 Tacoma Xtra Cab 3.4L 5-speed
    OME kit
    I had the same noise on both my 2nd gen and now my 1st gen. I think their valving upon extension is lacking, causing the suspension to rebound too rapidly. Never had the problem on 5100s.
    jafrisi likes this.
  12. Jun 29, 2017 at 9:10 AM
    Mike's Custom Toys
    Mike's Custom Toys Well-Known Member Vendor
    Grants Pass, OR
    There is also a batch of cs046r leaf springs that have been making clunking noises. The noise was traveling up the frame to sound like it was right under the cab. We went through a complete pallet at Wheeler's Off Road that all had the spring retainers over tightened. Something to check.
  13. Jun 29, 2017 at 12:05 PM
    FirstTimeFirstGen
    David
    Pacifica
    Maybe that's what happened with my dakars. Isolated it to one of the spring brackets. Went away after driving for a while, but OME sent me new guides for the brackets so I threw those in anyway.
  14. Jun 29, 2017 at 12:08 PM
    T4RFTMFW
    When the shocks reach full extension.
  15. Jun 29, 2017 at 12:32 PM
    gbollom
    gbollom Well-Known Member
    Weatherford Tx
    01 xcab TRD 4x4 5spd
    I don't have OME's but have the toytec coilovers and now have a clunk also(drivers side). I have rebuilt the whole front end and that didn't solve it. I will be replacing the body mount bushings my next days off as that may be the cause since mine are pretty worn. If it ends up being the coilovers at full droop I'll be figuring out a way to add limit straps as I can't stand the annoying ass clunk!
  16. Jul 1, 2017 at 9:24 PM
    bigwill837
    Will
    Austin, TX
    Thanks for all of the help guys. It sounds like it may just be the shocks. When the suspension makes the clunking noise, the shocks aren't at full extension or compression, but they are rebounding a lot (like when driving through a wash or over a bumpy road; typically at 20mph - 30 mph). I find it odd that it's only on one side of the truck though (passenger side).
    I'm probably going to just keep driving it and see if it gets worse, or if I can diagnose it more specifically.
    Eventually, I'll may just swap to the Bilstein 5100s and see if the clunking goes away.
  17. Sep 13, 2017 at 9:01 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Keep us posted .:confused:
  18. Sep 14, 2017 at 6:40 PM
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    good looking truck!
  19. Apr 7, 2018 at 8:45 PM
    03yodaor
    03yodaor Active Member
    Paul
    Nevada
    03 TRD 4X4
    Has anybody seen this issue with Toytechs in the front? I have an extremely annoying clunk in my front drivers side. I though it was my sliders hitting the body but I’ve only started noticing it this past month or so. I’ve had my sliders on for over a year. Installed my lift before my sliders. I feel like the clunking started as soon as I installed my tc UCAs last month. They’re properly lubed and installed leading me to believe the extra travel I’ve gained is causing my coilovers to pop when hitting bumps.
  20. Apr 8, 2018 at 8:06 PM
    TacoMatt253
    TacoMatt253 Well-Known Member
    1st gen 3rz-fe
    Old thread but do you know if there is a torque value for the spring retainers? My drivers side clunks and I would love to make it stop...this may be worth a shot. Thanks
