OME 3" lift kit w/o new rear shocks????
Discussion in 'Suspension' started by schleygo, Jan 6, 2011.
  1. Jan 6, 2011 at 8:48 PM
    schleygo
    schleygo [OP] Well-Known Member
    Daniel
    Ft Worth TX
    07 Dbl Cab Radiant Red
    Bilsten 5100s, Eibach Coils, 2" toytec AAL, LR UCAs, SC5 Matt Bronze
    Just bought new front 5100's from DSM.
    I am about one click away from buying this OME lift w 885 coil springs and 2" Toytec AALs
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    From reading for hours, I plan on installing the lift and setting the front 5100's at .85 and leaving the stock shocks in the rear to give it a 3" all the way around.
    Question is, will my stock rear shocks work with this set up for my 2007 Prerunner Dbl Cab? I do 99.5% on road driving, I am not worried about any off road issues at all.
    I am trying to do this w/o pissing off the ole lady by spending more than is needed.
  2. Jan 6, 2011 at 8:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it would be a good idea to get rear shocks, less of a possibility of topping them out. Also I would first set the 5100s at 0 and see how much lift that gives you, and if you need more later go to the .85.
  3. Jan 6, 2011 at 8:51 PM
    Tacomanator
    Tacomanator Boiling denim and bangin whores
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    i believe you need longer shocks with the AAL, could be wrong tho...
  4. Jan 6, 2011 at 8:57 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    You may be just on the edge of acceptable with your rear shocks ride zone. Also make sure your rear brake lines will reach without any issues.
  5. Jan 6, 2011 at 8:58 PM
    schleygo
    Daniel
    Ft Worth TX
    F#@$!!!!!!!!!!!!!
    I already paid for the front pre adjustable 5100's only. I was being a cheapskate and saving the extra $110 not buying the rears.
  6. Jan 6, 2011 at 9:09 PM
    schleygo
    Daniel
    Ft Worth TX
    I was hoping being a mostly street truck, it would be alright.
    I read about 1.5 AAL's not needing new shocks a few posts ago.
  7. Jan 6, 2011 at 9:10 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    You need rear shocks. I put this same lift on and I ran the stockers for a couple weeks and they top out over bumps and speed bumps. It sounds pretty bad when they top haha
  8. Jan 6, 2011 at 9:13 PM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    Just lifted mine today, i used upper control arms also (Light racing) to make sure alignment wasn't an issue.
  9. Jan 6, 2011 at 9:20 PM
    schleygo
    Daniel
    Ft Worth TX
    There goes that idea :(
  10. Jan 6, 2011 at 9:59 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    just leave the rear stock until you get new shocks.
  11. Jan 6, 2011 at 10:05 PM
    schleygo
    Daniel
    Ft Worth TX
    I think DSM will help me out. I emailed them and they said they will switch the order.
    Thank you Down South Motorsports!!!!
    The more I think about it, I will probably just put in Toytec 2" AAL's in the rear along w the 5100's set at 2.5. AHHHHHHHH, I am so confused on this!!!!!!!!!!!!!!1:confused:
  12. Jan 6, 2011 at 10:12 PM
    MLemis
    MLemis Active Member
    Morgan
    Tallahassee
    08 Prerunner Dbl Cab Longbed Black
    So putting the shocks at a 0 or .85 setting still gives the front lift?? I thought the settings meant how much lift you got in inches, as in 2.5 gives 2.5 inches of lift... Am I incorrect?
  13. Jan 6, 2011 at 10:17 PM
    schleygo
    Daniel
    Ft Worth TX
    MLemis
    I read in the suspension section that the OME 3" lift with 885 springs would have some sag in the front. to counter the sag, people setting the 5100's at .85 to give it a true 3" lift.
  14. Jan 6, 2011 at 10:19 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    yeah, but the 885's give about 2.5" of lift alone
  15. Jan 6, 2011 at 10:20 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    x2. exactly what i did with my truck
  16. Jan 6, 2011 at 10:43 PM
    MLemis
    Morgan
    Tallahassee
    Oh that's right I forgot you were putting springs on as well. I'm sure it'll look great lets see some pics when it's done!
