OME 3" Lift with Spidertrax Spacers for 285's
Discussion in 'Suspension' started by Chaaz, Sep 8, 2009.
  1. Sep 8, 2009 at 9:22 PM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    New member here with a 08 DC TRD LB - Indigo Blue. :canada:
    I've done lots of searching here and have decided on the following:
    OME 3" lift with 886 coils and Dakar leafs
    Spidertrax 1.25" spacers
    285/70/17 BFG ATs on the stock Rims.
    Just want to make sure that this setup will work. :confused:
    Don't care about a bit of rubbing - just don't want major rubbing.
    Cheers!
  2. Sep 8, 2009 at 9:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW!
    The 996's are only for use with a heavy bumper and/or winch.
  3. Sep 8, 2009 at 9:30 PM
    cjimenRR
    cjimenRR Be Good or Be Good At It
    North Hollywood, Ca
    12' Sport DC,LB, 4x4
    Why the spacers? If your running stock rims?
  4. Sep 8, 2009 at 9:35 PM
    azTRD
    azTRD Well-Known Member
    You should be good with the OME setup. The only question I would have is why did you decided to go with the 886's? I know they are typically recommended for people adding extra weight to their front end (i.e. winch).
    I have the OME rear setup with the full Dakar leaf pack and N182's... so far I've been very happy.
  5. Sep 8, 2009 at 9:40 PM
    azTRD
    I think you have to run the spacers if you go with a larger tire on the stockers... to avoid having the tire rub the UCA... No?
    Plus they give the truck a wider stance with the stock wheels too.
  6. Sep 8, 2009 at 11:12 PM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    Need the spacers to clear the UCA with 285/70/17. Also I like the wider stance.
  7. Sep 8, 2009 at 11:14 PM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    I have a friend who put in the 886's and likes them. I've ridden in his Tacoma and didn't noticed that the ride was to rough or firm. Also, won't have to worry about any sag in the future. :D
  8. Sep 9, 2009 at 6:52 PM
    cjimenRR
    North Hollywood, Ca
    Not true, look in my gallery I'm running that tire size and have plenty of uca clearance
  9. Sep 9, 2009 at 7:20 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    You have different rims... the stock wheels don't have enough backspacing.
  10. Sep 9, 2009 at 7:23 PM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    From what I can see from your pics, you are running aftermarket wheels. The difference in backspacing makes up for not having to use spacers.
    BTW, nice truck! :)
  11. Sep 9, 2009 at 7:32 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    great set up I would go with the 885 coils though
  12. Sep 9, 2009 at 7:35 PM
    r12rex
    r12rex Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Little off topic but nice LGT and STi! :)
    Kind Regards,
  13. Sep 9, 2009 at 8:08 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    Not really. thanks ya I miss the sti alot
  14. Sep 10, 2009 at 10:15 AM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    Yah, still haven't 100% decided on the 885 vs 886. But I might add an ARB bumper later and with my fat a$$ :eek: in the cab.....
  15. Sep 10, 2009 at 5:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek: I saw a guy on TTORA do that. BAD IDEA.
  16. Sep 17, 2009 at 4:01 PM
    Chaaz
    Chaaz [OP] Member
    09 DC TRD Sport LB
    Well now instead of the spacers I think I might go with some 17x9 Moto Metal 955's. :D
