OME 3" Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wicked Rebel, Jul 14, 2010.
  1. Jul 14, 2010 at 4:21 PM
    Wicked Rebel
    Wicked Rebel [OP] Member
    Eastern Shore MD
    05 Tacoma SR5 V6
    Alright I know there are a lot of threads on this subject, and I have read through just about all of them, so, sorry if this is just a repeat thread but I'm hoping to get some straight answers for my situation and desired setup. Here is what I would like to do: I own a 2005 Tacoma Double Cab. At this point is it completely stock, aside from a toneau cover. I am considering the OME Suspension Lift Kit ($699.99) http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72. I am confused on the following (bear with me, I am definitely a Noob):
    -Top Plate Spacers: What do these do?
    -Rear Options: Toytec Add-a-Leaf Standard, Toytec Add-a-Leaf for TSB(?), and Rear Block Kit (what are the differences?)
    This truck is my daily driver and occasionally sees mud and snow, but nothing extreme. Considering my options with this kit, what selections should I make to meet these following goals:
    -a FULL 3" lift all around and level
    -ability to fit 285's w/ my stock rims with minimal rub/trimming
    Please Help! Advice and opinions very much appreciated...:D
  2. Jul 14, 2010 at 4:50 PM
    Nirvana
    Nirvana Tesla Auto - Non union and proud
    Kris
    Bay Area, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, 285/70R16 KM2s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Top plate spacers can be used to add up to 3" of lift or 1/4" to fix the drivers side lean. Add a leafs are simply an extra leaf or leafs that add a little height and improve the ride quality in most cases. The AAL for TSB is for people who have had the TSB done to their rear suspension to fix sagging under load. A rear block kit is just a set of metal or plastic blocks that go between the axle and leaf pack to lift or lower the vehicle.
    For a full 3" with that kit do what the site says, add top plate spacers as the coils only add 1.5"-2" if I recall correctly and any of the rear set ups will bring you level I believe. You can always contact them on here under the vendors tab, they were always quick with responses to my questions.
  3. Jul 14, 2010 at 5:30 PM
    Wicked Rebel
    Eastern Shore MD
    05 Tacoma SR5 V6
  4. Jul 14, 2010 at 5:39 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
  5. Jul 14, 2010 at 5:43 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    do the aal and either one works great!
    The top plate spacer is what gets placed on top of the coilover assembly before you place it on the truck. you will get longer top plate studs which will allow you room for the spacer as you tighten the assembly onto the truck. the spacers are what gives you the full 3" of lift and for the double cab I think 885's, since you have no weight adding mods, are the best choice.
  6. Jul 14, 2010 at 7:04 PM
    Wicked Rebel
    Eastern Shore MD
    05 Tacoma SR5 V6
    thanks for the replies fellas, i'll post some pics whenever it gets done!
  7. Jul 14, 2010 at 7:14 PM
    DAN_FPC
    DAN_FPC Well-Known Member
    Dan
    Calgary
    09 Dbl Cab TRD
    Just wanna ask a side question... Can you run bilstein 5100's plus a coil spacer to get a full 3" lift up front. Then just AAL in the rear for 2 or 3" of lift? I know that the 5100's are adjustable but only to 2.5" and I've heard its not really 2.5".
    I have an 09 double cab. Or can i run different coils like 885s plus spacers with 5100's?
  8. Jul 14, 2010 at 7:19 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    Bilstein 5100 (2.5") aFe short ram intake KC light bar PIAA halogen Lights Hella Lights on top Yakima Load Warrior
    never ever ever evvvvver purchase a "plastic" block. blocks are already bad enough for the leafs... plastic will crack eventually, personally iv never heard of PLASTIC blocks...
  9. Jul 14, 2010 at 7:24 PM
    tacomarotto
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    The OME setup is awesome. get it. make sure you get new shocks in the front. prefferably the OME nitro charged shocks.
    for the rear get a single AAL or a 3 leaf pack. Toytec makes a good Long AAL for a "smoother" ride. its still firm but its not too bad. if you wheel you truck then get extended shocks for the rear.
    http://www.toyteclifts.com/index.ph...tegory_id=116&option=com_virtuemart&Itemid=72
    youll be able to fit the 33s with this lift. no trimming required.
  10. Jul 14, 2010 at 7:30 PM
    tacomarotto
    Jon
    New Orleans, LA
    FJ Cruiser 07'
    my rule of thumb is to never STACK lifts... i wouldnt do it.
    if you get the 885 and dont have any additional weight (110lbs) on the front you will get a good 3" but it will be stiff....
