OME 3" vs 5100 2.5"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by customz, May 3, 2010.
  1. May 3, 2010 at 8:10 AM
    customz
    customz [OP] Well-Known Member
    09 prerunner access 2wd 4cyl 5sp
    Hello Gents,
    Before you flare I have searched all weekend and find varying opinions all over the board. I know several things: ride will be compromised with 2.5 setting on 5100s and alignment will be at the limit. The springs will be compressed and 285s will not fit on stock wheels wihout spacers. 255s will but selection is limited.
    My goal is a leveled reliable vehicle with 33s on stock wheels as inexpensively as possible...
    My questions regarding the OME 3" vs 5100s are:
    Does the 3" setting still put the alignment settings at their limits(or does emu correct this somehow)?
    Would UCAs be needed to fix this on the 3" emu setting?
    Does the EMU or any other lift ride better when the stock springs are replaced up front (rather than the compressed stock coils)?
    Would you rather run an inferior 255/85-16 (loud, heavy, no-mileage warranty)? Or a higher quality michelin, etc 285/75-16 on wheel spacers?
    I know this lift has been done before in many configurations. PLease help.
  2. May 3, 2010 at 9:42 AM
    sooner02r1
    sooner02r1 Well-Known Member
    I've been running Bilstein 5100s at 2.5" for about 30,000 miles and I think they ride great, handle great, and are decent offroad. My truck aligned in factory spec just fine (both before and after Camburg UCAs), and I'm running 285/75/16s on aftermarket wheels, and I think the setup is perfect. I have no experience with the OME stuff, but I know the alignment will be the same. The factory control arms/spindles are what determines the alignment, and OME does not change this.
  3. May 3, 2010 at 10:16 AM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    Go bilstein 5100's set at 2.5" and a 1.5" block in the rear.
  4. May 3, 2010 at 10:23 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Why?
    And why recommend a block over an AAL?
    Also, isn't the OME stuff more like 2.5-2.75 or is it different because you have a prerunner? I have a TRD sport double cab and am expecting about 2.5 from the OME lift. And I plan to do the TSB AAL in the rear to level it off. I do not plan to get UCA's.
    That is my plan and I hope I can stick to it. I'm not buying until later this summer (after 2 long distance trips).
  5. May 3, 2010 at 10:25 AM
    Joehs
    Joehs Okie!
    Joey
    Broken Arrow, OK
    12' Tacoma Sport
    Listen to the man. I've seen it in person, and it's quality.
    As for the thread, I'm also running bils @ 2.5" and it's fine. I'm running an awkward tire size, as I got them for free, but the alignment wasn't too far off when we put the bils in. Rides great on the highway and the streets, haven't had an opportunity to get it off roads yet, but I will very soon.
  6. May 3, 2010 at 10:33 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    i'll flare a little, but help in the end.
    if you found that the alignment at 2.5" is the limit w/ the 5100s, what makes you think it will be any better w/ the OME at 3"?! reason that out and search a little harder next time!!
    ok, yes, ANY lift over 2.5" you will need UCAs to correct the alignment. struts cannot do anything to adjust alignment in it of themselves.
    yes, you would need new UCAs if you run the OME at 3"
    the OME springs are a higher spring rate than OEM. i believe that chris4x4 stated that OEM springs compressed are about the same rate as teh OME ones when used w/ teh OEM shocks.
    tire choice all depends on how you will use the truck. hwy, offroad, trailrig, sand, mud, etc...
    with all that said, i ran the 5100s at 2.5" setting w/ OEM UCAs for almost 2.5 years. i had great tire wear and alignment.
  7. May 3, 2010 at 10:36 AM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    5100's at 2.5 with 285's, stock UCA's and NO spacers. No problems on my ride.
  8. May 3, 2010 at 10:40 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ but aftermarket wheels right?... there is no way to run OEM 5.25" or whatever BS wheels w/ 285s w/o rubbing on the UCA.
  9. May 3, 2010 at 3:44 PM
    Flynn Diesel
    Phoenix, AZ
    Yes, aftermarket 17x9's
  10. May 3, 2010 at 3:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2. Yeah thats what I was about to ask him.:rolleyes:
  11. Aug 25, 2010 at 9:41 PM
    cevallos.j
    cevallos.j Well-Known Member
    Jorge
    Coronado
    2006 Prerunner access cab
    Maybe I missed something, but do you run the 5100's all around or just in the front?
  12. Aug 25, 2010 at 9:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Actually, The OME 885's are a little softer than the 5100's with a stock spring set to 2.5"...
  13. Aug 25, 2010 at 9:45 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    the fronts are the only ones that are adjustable to provide lift. the rears are slightly longer to accommodate up to 2" of lift in the rear from some other means. you dont have to run the rears if you have the fronts
  14. Aug 25, 2010 at 9:50 PM
    cevallos.j
    Jorge
    Coronado
    awesome, thanks! also my trucks front end is 2 inches lower than the rear. With the 5100s raise the front to be level or can it make it higher than the rear? sorry im a bit confused
  15. Aug 25, 2010 at 9:54 PM
    jhodge83
    SC
    17 XLT Sport
    default settings are 0, .85, 1.75, 2.5. can be made to handle different heights when paired w/ different coils
  16. Aug 25, 2010 at 10:00 PM
    cevallos.j
    Jorge
    Coronado
    can it handle 2.5 with stock coils? I plan on a bit of offroad trails every now and then
  17. Aug 25, 2010 at 10:01 PM
    jhodge83
    SC
    17 XLT Sport
    most run it w/ stock coils
  18. Aug 25, 2010 at 10:42 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    I am runnung full OME all the way around, stock UCA and 255/85 (KM2 are in NO WAY inferior). SHe is aligned perfectly and is GREAT on and especially off road.
  19. Aug 25, 2010 at 10:53 PM
    Jetta1cab
    Jetta1cab Well-Known Member
    Carlos
    Yuma, Arizona
    08 TRD Sport PreRunner
    Bilstein 5100s @ 0 with OME885x coils. Toyota Rear TSB. Billet grill inserts.
    I've got an '08 double cab PreRunner and I am running 5100's on the front set at 0 with OME885x coils. Day and night improvement over stock TRD/Bilstein. I had the rear TSB performed and the front is slightly (and I mean slightly...) higher than the rear. I didn't install spacers in the front either. Tires are 265/70/17 Hankook ATM. No rubbing and I am very pleased with it! I'm waiting to install Fox piggyback shocks in the rear that I bought from another TW member few weeks ago.
    Link to my build w/pics of lift.
    http://www.tacomaworld.com/forum/2nd-gen-builds/105729-buitragos-build-08-taco.html
  20. Aug 30, 2010 at 12:56 PM
    Gabex35
    Gabex35 Shinty Killer
    Gabe
    San Diego
    2014 4 Runner Trail Premium
    King OEM Performance Series with compression adjusters, Custom rear coils drom CSS, 22% Tint, Method Race NV's 17x8.5, 285/70-17 MTR's, AllPro welded Sliders, Cobra CB, Gobi stealth roof rack, Rigid 40" e series & duallys out back
    I spoke with some of the gentleman from Toytec the other week and they stated that the ride is bouncy with 5100's (set at Zer0) and the 885's. Did you encounter any of that?
