OME 5mm spacer fix "Tacoma Lean?"
Discussion in 'Suspension' started by whitebread, Feb 27, 2010.
  1. Feb 27, 2010 at 2:07 PM
    whitebread
    whitebread [OP] Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I did a search and nothing pertinent turned up.
    Clearly the Tacoma has a driver-side lean. Mine measures about 1/4" in the rear with the front being relatively even. The OME suspension kit I purchased came with a 5mm spacer for the front-driver side to counteract the Tacoma Lean. Because I am measuring the lean in the rear, it seems counter intuitive to put this space on the front. Does it actually level out the truck?
  2. Feb 27, 2010 at 4:14 PM
    Silver_Taco
    Silver_Taco Senior Member
    Frederick, MD
    Sure does. Had mine installed yesterday.
  3. Feb 27, 2010 at 8:56 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    5mm spacer=10mm of lift
  4. Feb 27, 2010 at 9:42 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yes, it works.
    I admit it does seem odd to put it in front.
    Switched my suspension to an OME setup and left it out at first, then went back and popped it in because it still leaned. The 5MM spacer leveled it out. It has been 9+ months since and it's still sitting level.
  5. Feb 27, 2010 at 10:05 PM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Great info. Apparently OME knows what they are doing. ;) Thanks!
  6. Feb 28, 2010 at 7:17 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    crossfithubby likes this.
  7. Mar 3, 2010 at 4:26 PM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Well, you guys were right. Measures dead level with 7/8 tank of fuel. The shop didn't want to put the spacer in...they said they always leave them out because it 'didn't make any sense.' I requested they use it...and I am very glad I did. Thanks for the help guys.
  8. Mar 3, 2010 at 5:24 PM
    Silver_Taco
    Frederick, MD
    ^^Sweet ride man, congrats.
  9. Mar 7, 2010 at 12:48 PM
    guts
    guts New Member
    New Orleans, LA
    '10 TRD-Offroad, DC, 4x2, Pyrite
    I'm interested in the fix you used for your truck's lean. What exactly is the OME suspension kit? Can you give me the actual part order number or where I can buy one? Is it a big job to install, and would the Toyota mechanics be familiar with it or should I get it done independently? Thanks
  10. Mar 7, 2010 at 1:00 PM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    It is a 5mm spacer that goes on the front driverside old man emu model 90000 strut. It is placed between the welded on ring and the spring seat.
  11. Mar 7, 2010 at 1:35 PM
    guts
    guts New Member
    New Orleans, LA
    Thanks for info. Truck is new, with TRD-offroad suspension. I'm not looking to change suspension or add lift to truck, just correct the lean. Is there a spacer that would work on the existing suspension? What is the easiest fix for this? Do I have to change everything?
  12. Mar 7, 2010 at 1:44 PM
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Other than making a custom shim, I am not aware of any. I would just bitch and bitch at Toyota about it...but that is me. ;)
    FWIW, with my original leaf packs, the truck was pretty level (the lean was about 1/4"). When they did the suspension TSB the lean became very noticeable and measured about 5/8".
  13. Nov 18, 2010 at 9:47 AM
    PAArcher
    PAArcher New Member
    Pittsburgh
    Off Road 4x4
    Wouldn't this kit work..without the need to replace the strut? It's much cheaper if it works
  14. Nov 18, 2010 at 10:14 AM
    PAArcher
    PAArcher New Member
    Pittsburgh
    Off Road 4x4
    If u want to go the 5mm spacer route (plan a) you also need the pair of ome struts because the 5mm spacer doesn't fit on the Toyota stock strut.
    that is because the spacer mounts under the coil seat on the Ome strut and The ome strut is thicker in diameter than the stock strut. It is also unclear if more than one spacer can be used if needed. Cost of struts and one spacer is $315. Lift with one spacer 1/4 to 3/8 inch.
    The other option (plan b) is the 10 mm lift enhancer kit, which provides 1/2 to 5/8 lift and installs on top of upper strut plate so it eliminates the need to buy struts. Cost of this option is $67. Big difference.
    The question is how much lift do you need to level the ride? If 1/2 inch isn't too Much go with plan b.
  15. Nov 19, 2010 at 10:08 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    If you want to just correct the driver side lean, this would probably be your best bet. Its just a single spacer that sits on top of the shock. You do not need longer top plate bolts :thumbsup:
    -Dylan
    02Taco4x4Trd likes this.
  16. Nov 21, 2010 at 8:24 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Hey boys,
    I recently put on OME N140S struts with 885 coils with no trim packer, and I'm about 24 1/2 on the driver side and 25 on the passenger side front end. How would I make the driver side come closer or about 25" from center of hub to top of fender? Would a Toytec 1/4 top plate spacer help?
    - Richard
  17. Nov 21, 2010 at 9:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes.
  18. Nov 21, 2010 at 9:06 PM
    eight3one_offroad
    Richard
    Thanks Chris. I think I remember talking to you about this but wasn't sure if I could stack a top plate on the OME setups.
  19. Nov 21, 2010 at 9:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As long as its only 1, its not an issue.
  20. Nov 21, 2010 at 9:54 PM
    VTaco08
    VTaco08 Well-Known Member
    Vermont
    08 Tacoma 4X4
    OME Complete lift kit, Dakar leaf pack, LR UCA's, G2 1.25 wheel spacers, Pro Comp 17/8 5001, derrped badges.
    What if I was to use the top plate spacers on the OME lift to get the full 3" lift in the front am I SOL as far as correcting the taco lean??
