OME 5mm spacer fix "Tacoma Lean?"
Discussion in 'Suspension' started by whitebread, Feb 27, 2010.
  1. Nov 21, 2010 at 9:57 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    I don't think I would feel comfortable stacking top plate spacers... just wanted to fix the driver side sag (lean)
    - Richard
    VTaco08 - The top plates better not be thicker then 1/4 because that means you'll need extended studs.
  2. Nov 21, 2010 at 10:02 PM
    VTaco08
    VTaco08 Well-Known Member
    Vermont
    08 Tacoma 4X4
    OME Complete lift kit, Dakar leaf pack, LR UCA's, G2 1.25 wheel spacers, Pro Comp 17/8 5001, derrped badges.
    I was refering to the spacers that came with the ome lift, if I used those I would need new struts? Pretty sure they are 1/4 inch spacers.
  3. Nov 21, 2010 at 10:04 PM
    VTaco08
    Vermont
    08 Tacoma 4X4
    haha My bad studs not struts. Im an idiot.
  4. Nov 21, 2010 at 10:21 PM
    eight3one_offroad
    Richard
    No worries, Yes you can use the 5mm trim packer on one side for the lean. I bought the struts off a guy on TTORA already assembled. I was out of luck because he didn't install the packer. It's all good, I'll get a 1/4 TP spacer and call it done!
    - Richard
  5. Nov 21, 2010 at 10:23 PM
    eight3one_offroad
    Richard
    Are your OME struts already on the truck? the 5mm packer goes on the lower spring seat...
  6. Nov 21, 2010 at 10:27 PM
    VTaco08
    Vermont
    08 Tacoma 4X4
    Negative, not on the truck yet I was just wondering so that when I order the lift I can have it done in one shot. So I can put the 5mm trim on as well as the 1/4 inch spacer to get the lift I'm after? Sorry to keep picking just trying to do it right. Thank you, you have been a huge help.
  7. Nov 21, 2010 at 10:34 PM
    eight3one_offroad
    Richard
    VTaco - If you are getting OME 9000 Nitrosports paired up with OME coils I would sugguest having them install the 5mm trim packer on one of the struts to fix the lean. You don't need a 1/4 top plate spacer as the trim packer will be fixing the problem for you. You'll definantly be one side higher then the other if you decide to run 5mm trim packer + TP spacer. This probably what you wouldn't want. No problem always here to help. I hope you understand what I explained here :)
    - Richard
  8. Nov 21, 2010 at 10:42 PM
    VTaco08
    Vermont
    08 Tacoma 4X4
    Thanks I have heard of the Taco lean and now I know of a solution. You've been a huge help. Brownie points for you Richard.
  9. Nov 22, 2010 at 12:14 AM
    eight3one_offroad
    Richard
    I'm glad I could help another member out right here on my computer, Your welcome. Always down to lend a hand in times of need :)
  10. Jan 1, 2011 at 12:02 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Hey can these be used with billy's?
    if so I need one for the front and the back right?
  11. Jan 5, 2011 at 3:43 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    They work on the OME shocks only and they are only for the front.
    The 1/4 spacer that i posted earlier in the thread will with on the Bilsteins.
  12. Apr 14, 2014 at 2:28 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Link takes me to "Unfortunately that page can't be found ;( "
  13. Oct 26, 2015 at 4:05 PM
    halo7
    halo7 New Member
    Geoff
    2009 Tacoma TRD Sport
