OME 880 or 881
Discussion in 'Wheeler's Off-Road' started by 2KTacoPr3runn3r, Dec 8, 2010.
  1. Dec 8, 2010 at 11:45 AM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    I am not sure which to put on my truck. I have a 2000 prerunner 4cyl. i will be running them with stock shocks and no aal. im looking for the truck to sit level or slightly above level. any opinions?
  2. Dec 8, 2010 at 12:03 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Then the only real option is the 880s.
  3. Dec 8, 2010 at 12:06 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    only real option? meaning the 881's will be too much of a lift?
  4. Dec 8, 2010 at 12:15 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Correct. You have a 2wd (less weight), and its a 4cyl (less weight), and no lift in the rear. 881s would give you some serious BRO lean.
  5. Dec 8, 2010 at 12:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    For comparison:
    I had a 96 tacoma 4WD w/ 3.4L Access cab with 881 coils = 2" lift (front lift).
  6. Dec 8, 2010 at 12:22 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    okay thanks
