Ome 880
Discussion in '1st Gen. Tacomas (1995-2004)' started by Firefighter160, Jan 31, 2010.
  1. Jan 31, 2010 at 3:14 PM
    Firefighter160
    Firefighter160 [OP] Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    How much lift would I get with OME 880 coils? Everywhere I look says something different from .85'' to 1.75''... Going on an extra cab 4cyl.
  2. Feb 1, 2010 at 10:36 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    Uhh would you also be purchasing OME shocks as well? That setup gave me 2.25" of lift (not exactly measured but the taco rides slightly higher than it did with the 2" rough country spacers that came on the truck).
    I would also recommend 881 coils instead. They are stiffer and could handle a fabricated bumper or bull bar if you so wished to get one in the future. The OME parts for the front are listed in my description if you need reference.
  3. Feb 1, 2010 at 10:40 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The amount of lift you get with a new set of coils varies alot depending on the model of your vehicle. A 4cylinder single cab is going to get a lot more lift than a Double Cab V6.
