OME 881 or Bilstein on 2.5
Discussion in '1st Gen. Tacomas (1995-2004)' started by 07toyota1991, May 8, 2017.
  1. May 8, 2017 at 4:57 AM
    07toyota1991
    07toyota1991 [OP] Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    I am having a hard time deciding which route to take on my 99 Tacoma single cab 2.7 4x4. I currently have the Bilstein 5100 on the middle setting with a AAL in the rear and am sitting about 3/4" higher in the rear. I am looking to get as close to level as possible whether that be the Bilstein 5100 on the highest setting or a set of OME 881 lift coils. Pictures and or opinions are all welcome!
    Thanks
  2. May 8, 2017 at 5:49 AM
    Buck18
    Buck18 Well-Known Member
    Buck
    Euharlee GA
    01 Tacoma DC 4wd Limited TRD
    881's on Billie 5100's, Dakar's and 5100's, grey wire mod, 265 75 ko2
    Just my opinion, but I'd go 881. I've got bilsteins on my Double Cab. I've had 880, 880 on 2nd notch, 881, 881 with 3/8" wheelers poly spacers, and Eibach 620. For MY setup 881 are perfect. They ride better than any of the other combos I've tried. It sits dead level with Wheelers AAL. Sits 3/4"high in rear with Dakar's. you'll be a little high at first but should settle out level with no winch or aftermarket front bumper or no armor. Hopefully someone with a reg cab chimes in If not try a google search.
  3. May 8, 2017 at 10:47 AM
    07toyota1991
    nobody has either setup on a single cab...
  4. May 8, 2017 at 11:32 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  5. May 8, 2017 at 10:49 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    My vote is for the 881's as well. You should have a better ride with this setup.
