Ome 881 use spacers or set at 1"?
Discussion in 'Suspension' started by austinramsay, Aug 13, 2012.
  1. Aug 13, 2012 at 5:04 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Got a set of 881s today. Looking to get 3" of lift. I have a 1" daystar spacer lift to use or set the 5100s at 1" middle setting. Which should i use?
  2. Aug 13, 2012 at 7:29 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Bilsteins, will be a slightly better ride than a poop spacer!
  3. Aug 13, 2012 at 7:56 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Haha even though id be compressing the 881s? Would i get 3" out of that?
  4. Aug 13, 2012 at 8:08 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Be very very careful and consider this a warning:
    Compressing stock coils is one thing but when you compress a 'lift coil' , it puts a tremendous amount of pressure on the lower coil seat on the strut.
    Depending on the strut... You could break the welds off the lower coil seat.
    Back in the old days of TTORA, I remember a guy who blew out his struts from doing lift coils & spacers, etc.
  5. Aug 13, 2012 at 8:31 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Thats what i was worried about. Would it be safer to use the spacers? They're only a 1" lift so they arent too big.
  6. Aug 13, 2012 at 9:53 PM
    Janster
    Jandy
    Lancaster, PA
    It doesn't matter how you slice it..... a coil spacer OR 1" on the bilsteins... Is the same amount of PRELOAD on the spring.
    Do some more research...I've read that some guys are using Top plate spacers instead of coil spacers to gain additional lift.
    You may also want to do some research on other lift coils....there are 884's, 885's and 886's - all of which I know nothing about.
  7. Aug 13, 2012 at 10:00 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Sorry I do have the top plate spacers not the coil spacers :eek: my bad..
  8. Aug 13, 2012 at 10:01 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Trim spacer.
    IIRC, If you want a full 3" you need to get the Toytec Eibach springs. Not sure but i think the ome 883's give a bit more height.
  9. Aug 13, 2012 at 10:35 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Thanks for the info guys! Ill keep looking around. Ill keep the ome's for a while until i find a good deal on used eibachs i guess.
  10. Aug 14, 2012 at 6:16 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    All trucks varies but according to Wheelers you should be able to add a 10mm top plate space to get a 3" or close to it lift. But your front CV's will soon hate you.
