OME 881
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kolar, Jul 1, 2011.
  1. Jul 1, 2011 at 10:22 AM
    Kolar
    Kolar [OP] Active Member
    Eric
    South Texas
    03 PreRunner stock
    Ok my 881s arive today. I have never changed springs before and need a little help. I was going to go with the 882s but after talking to Slee OFF Road the talked me into going with the 881s because i am going to be using my stock struts. All I wanna do is lift the front end of my truck back to stock height after installing my new ARB Bull Bar Bumper. After installing the bumper this added an additional 150 lbs. to the front of my truck dropping the front end approximately 1.75" to 2". With the stiffer 881s I hope to achieve the stock height or just a bit more to level the truck. Has any one had any experience in this matter?
  2. Jul 1, 2011 at 10:32 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    I put 881's on with nitro chargers and got about 1.75-2' so that looks to be in your range. so your not going to replace the shock absorber itself, and reuse the existing one?
  3. Jul 1, 2011 at 10:40 AM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    yes
    I am going to replace the spring only.
  4. Jul 1, 2011 at 10:42 AM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    All I need is the stiffens of the spring to hold the front of my truck up. Was it had the change the springs on you're truck ? I have never done this and don't know what to do to change them.
  5. Jul 1, 2011 at 11:09 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    It was cake for me because i ordered the new strut assembled (paid the extra 120, but well worth it in my mind). i just unbolted the old unit and installed the new one. i didnt want to have to mess with changing out the hardware and taking it to a shop or renting a spring compressor. i wanted to have the stock unit on hand, fully assembled.
    i would recomend replacing the shock absorber also if your going thru the trouble of getting springs.
    I guess you could use the old shock, and the spring would in fact give the support, but the shock may not work well with that spring, and you could end up with a harsh ride......... thats a whole other subject. theres tons of reasons on this site as to what shock spring combo to use, or not to use, and why.
    but in theory, the spring supports the weight of the truck and the shock helps with bumps, to put it simple. So yes, as long as that spring fits on that shock, it will help the front end sag
  6. Jul 1, 2011 at 11:11 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    there is a ton of info on this subject on this site. look around for awhile, it may change your ideal setup
  7. Jul 1, 2011 at 6:53 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The most challenging part will be compressing the stock spring/strut assembly to get it apart. Then reversing the process with the new spring. A daunting task at best because of having to use a spring compressor.
    My $ .02.
    If you are going to the trouble of doing this, you might as well replace your stock shocks with something that can handle the much more stout spring you plan to use. It is very possible that the OME 881 spring will overpower you stock shock and you will end up having to replace it anyway.
    There are a large number of threads on this site from guys who have gone through all this stuff you are facing. I am fairly certain the consensus among those that have replaced their coil springs would be to replace your shocks at the same time.
    This is something you will have to gauge for yourself but at least read about the experiences of others before you do this.
  8. Jul 1, 2011 at 8:46 PM
    Scott78
    Scott78 Well-Known Member
    Scott
    Vacaville, CA
    '13 STI Hatch\\
    Don't be cheap or foolish.
    Replace the shocks.
  9. Jul 1, 2011 at 10:38 PM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    first i used the spring compressor to installed both the bilstein and 881s. i noticed something doesn't look too good so i took it to the shop to redo the assemblied again. save me some time there and just brought it home to install onto car.
  10. Jul 2, 2011 at 1:36 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    I got new stock struts and I installed the OME 881 springs on them. This did exactly what I was wanting to acheve it picked the front end up to level the truck out. The front is now just a little higher than stock. With this combination it levels the truck right out and the ride is excelant.
  11. Jul 2, 2011 at 2:53 PM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    nice ! everyone has an opinion on what works and what doesnt even though they never tried it. Glad you got the desired results
  12. Jul 3, 2011 at 12:56 AM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    :worthless:
  13. Jul 3, 2011 at 11:05 AM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    Ok ok pics will be coming soon.
  14. Jul 3, 2011 at 3:35 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    The first pic is of the front end sagging and the second is of the front end with the new springs and struts.
  15. Jul 3, 2011 at 4:13 PM
    CHPTR11
    Dan
    Pacific NW
    2004 TRD Tacoma
    ^^^ Sweet, cant wait to get mine installed.
    You running 265/70's or 265/75's?
  16. Jul 3, 2011 at 4:16 PM
    Scott78
    Scott
    Vacaville, CA
    '13 STI Hatch\\
    Looks sharp man
  17. Jul 3, 2011 at 6:22 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    Thanks guys! I am running 265/70s this has been alot of work I have done to my Taco in the past week. I hit a deer about a year ago and busted my grill up and dented the stock bumper and tore up the plastic air damn. This week I installed the new ARB bumper, HID lights, disabled my DRLs and installed new struts and OME881 springs. It is all worth it though talk about functionally! Bring on the deer Baby!!!
  18. Jul 4, 2011 at 4:49 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    Very nice ! looks good. lot of work at once, feels good when it all comes together
  19. Jul 4, 2011 at 10:05 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    Yes it does! It looks great!
  20. Aug 1, 2011 at 2:30 PM
    Catcrazed
    Catcrazed Save a horse ride a Railroader
    Bryan
    NW Oregon
    91 Flatbed 3.4
    91 Toy flatbed,4.88's ARB,285's,3.4 V-6 Swap
    Did you use the 10mm top plate spacer or just the 881? Also do you have a winch in there? Just tryin to fig out what route im gunna go.
