OME 881s and Bilstein 5100s on 1st gen?
Discussion in 'Suspension' started by scocar, May 26, 2010.
  1. May 26, 2010 at 10:58 AM
    scocar
    scocar [OP] It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    So I have been researching the heck out of this after I realized my original coils are sagging more than an inch below stock.
    I just bought the Wheeler's 5-pack for the rear, which will lift about 1.5" ( I have a cap and heavy rubber mat in the back, probably about ~200 lb constant load). Also have Bilstein 5100s on the rear.
    I bought the front Billies thinking I could level it, but realize now I would need to crank them up to the top setting to get anywhere near level with my worn out coils, and I don't want to compromise ride quality like that. So now I am looking at OME 881s.
    So a few questions:
    1. Is the stock rake on this truck 1.5 inches? (note my truck spec in profile: I bought it used with 101K miles, so I have no reference). I saw this stated in a 2003 offroad article on an OME lift. I am using this for basing my lift and rake numbers.
    2. Despite what ARB claims on its OME spec sheets (must use OME struts on 881s), can I run the Bilstein 5100s on the lowest "zero lift" setting with the 881s? I think this will get me to about only 1 to .75 inch rake, which would be fine.
    3. If I wanted more lift in front after that to reduce rake, could I raise the Billies to the middle setting (which I still have not been able to confirm is 1 or 1.25 inches of lift?).
    4. If not, could I use OME 10MM spacers?
    Thanks for any sound wisdom and experience you can provide.
  2. May 26, 2010 at 11:24 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    The stock rake is about 1"
    And you will be fine with running the 5100's and OME coils. It just wont ride as well as the OME shocks, bc they arent made for that coil. And If you want to go higher, you can set the 5100's to next notch(.85") But it will ride rougher...
  3. May 26, 2010 at 3:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    What He said ^^^^
  4. May 26, 2010 at 3:50 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Thanks, guys. I know this isn't an exact science, but this helps. An original design 1" rake makes this all work out better...
    I'll stop agonizing and place my order now...
  5. May 26, 2010 at 3:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    do it man.......i got that setup....lovin it!!!
  6. May 26, 2010 at 4:10 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Hey, Will! Dude, I so don't know why I bothered with all the research. I just should have ordered your setup, but I am too picky and have to do everything the hard way. Everything. Maybe the visions of dollars flying out of my wallet slowed me down...
    But at least I learned a lot in the process!
  7. May 26, 2010 at 6:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    learning is better than finding out the hard way with the wrong stuff.:)
  8. May 26, 2010 at 7:43 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    sheesh. damn newbies...arent there already about 918545 threads on here about this?
    now that i have all of my stuff i'm still undecided as to what to do exactly...fronts set at 0 or mid, to rake or not to rake...gahh! i have until 2pm tomorrow to decide so no pressure.:goingcrazy:
  9. May 26, 2010 at 7:46 PM
    98lowflyingtacoma
    98lowflyingtacoma Well-Known Member
    Phoenix
    1998 Tacoma Prerunner
    i went with those on my 98... very good. would not have minded to through the 10mm spacer in on top however just to get a bit more clearnance
  10. May 26, 2010 at 9:48 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    Hey, what the hell are you doing int his thread?!?!?! I had very precise questions. And I do homework. And I bother to punctuate.
    Did I say "yo some 33 liek these wheels lift foit?" No, I did not.:mad:
    And if I am going to pay a shop to install these coils, I don't want to go back and have them change it. What do I look like, a friggin' ATM?:rant:
    You should probabaly set them on zero so you have a little rake, and then when it snows and your bed fills up, you won't suffer from Bro Lean:puke:
  11. May 26, 2010 at 9:56 PM
    MTgirl
    Weesa
    i punctuate! i just refuse to shift or use ' 's most of the time.
    and im here because ive have been stalking everyone who joined in the group buy. still gathering knowledge before the big day.
    and im not an atm either, although it feels that way now. im sooo over my initial budget. and also paying for front end install. hence the panic over the settings on my shocks.
