OME 881's or 883's?
Discussion in 'Suspension' started by tacomakid96, Mar 21, 2011.
  1. Mar 21, 2011 at 4:36 PM
    tacomakid96
    tacomakid96 [OP] Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Im going to be buying a new lift soon, and will be buying the Toytec/OME full lift kit. My question is it has 3 coil options, 881's and 883's "Dont need the 882's." The 881's need a top plate spacer to achieve full 3'' of lift, and the 883's dont. What would be the ride quality difference between the two?
  2. Mar 21, 2011 at 4:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    IIRC, The 883's dont fit your truck. You have either 880's, 881's or 882's
  3. Mar 21, 2011 at 4:39 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    We'll im sure glad I asked then:D
    Thanks chris
  4. Mar 21, 2011 at 4:40 PM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    Don't know anything about the 883s, but I have 881s on my double cab and I get right about 2"-2 1/4" of lift. Seems right with the 1.5" AAL.
    Ride quality is pretty good. They were pretty stiff at first but they are broken in really nice now. On dirt roads it flys.
  5. Mar 21, 2011 at 4:43 PM
    tacomakid96
    Phil
    Out n' about
    2008 Tundra
    Ya I will be getting the top place spacer to get the full 3'' because I have new 285's waiting:woot:and then the toytec aal that says 2'' lift so I think that should turn out pretty level.
