OME 882 vs. 883
Discussion in 'Suspension' started by tomtom, May 10, 2013.
  1. May 10, 2013 at 8:59 AM
    tomtom
    tomtom [OP] Well-Known Member
    The Desert SW
    2012 FJ
    I'm running OME 882s + 10mm top plate spacer with an Elite front bumper and starting to show some rake. I'm looking to add a BudBuilt skid and a Warn winch (~130 lbs) but don't want the nose dipping down anymore.
    Even though 883s are 20mm shorter would the 590lb spring rate bring the nose back to level?
    Are there other options I should be considering?
  2. May 10, 2013 at 3:54 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    883's won't get you level again. You're best route to level it out again is some weight over the back end, and reducing weight as much as you can up front. Might not be able to cut much weight from the skids, but you can probably reduce the weight of the winch. Run a synthetic line and a nylon fairlead and you can keep a winch setup close to 50lbs.
  3. May 10, 2013 at 3:59 PM
    tomtom
    The Desert SW
    2012 FJ
    Poopers. Looks like I'm researching winches then. Was going to get one of the new Warn Zeons with synthetic. I'll have to poke around to see what might be a lighter replacement.
  4. May 10, 2013 at 6:00 PM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Not sure if you want Eibachs but they are 620lbs springs. Those might suit you better.
  5. May 10, 2013 at 6:13 PM
    tomtom
    The Desert SW
    2012 FJ
    Do you know the spring height?
  6. May 10, 2013 at 7:59 PM
    tomtom
    The Desert SW
    2012 FJ
    Hmmm, the Warn M8000-S comes in at 55 lbs. Hmmmm.
