OME 883 Coils W/ 5100's
Discussion in 'Suspension' started by cfenn, Jan 8, 2009.
  1. Jan 8, 2009 at 3:09 PM
    cfenn
    cfenn [OP] Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    Possible to run them but with the 5100's set at 1.75 lift????
  2. Jan 8, 2009 at 3:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i dont think those coils are supposed to be preloaded, so no..........the 5100's would need to be at stock setting.
  3. Jan 8, 2009 at 3:15 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    You can use the 5100's but you'll have to keep them at the stock setting.
  4. Jan 8, 2009 at 3:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You could possibly get away with running them on the .8" setting, but nothing more. The 883's are a bit shorter than the 884's adn 885's, but are a 590# spring rate.
  5. Jan 8, 2009 at 3:54 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    x12... :D
